Would a stock LS/VTEC blow quick?
Old Jan 15, 2007 | 09:54 AM
SolAssassin's Avatar
Default Would a stock LS/VTEC blow quick?
Ok guys. Let me start off by saying that lately I have been doing my research on this topic. It seems that a lot of people are saying that a stock LS/VTEC build will grenade shortly. I understand that it is because of the the piston valve lash. My question is, could I mate my B16 head to my LS block properly to keep reliability? I'm not too interested in building up the motor because I am looking to see how inexpensively this could be done without cutting any corners. I got a PR3 head for $150 locally in mint condition as well as an LS block (also in perfect condition) for $20. So far I have a full block for $170, and for that I think I am doing well. I'm willing to buy ARP studs and am open to suggestions on torque specs. What can I do to keep this motor from blowing up once I get it in? Also, I don't have the distributor. Is there a best choice for a distributor/ecu combination? I'm sorry for all my noob questions... I just don't know whether I should turn around and sell this stuff or go for a build if I can do it cheaply enough. My budget is limited, and whatever play money I have for motor build pretty much goes into my H22A in my del Sol (which for the most part is finally all done).
Old Jan 15, 2007 | 10:22 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Would a stock LS/VTEC blow quick? (SolAssassin)
No. As long as you do it properly it can be just as good as a stock motor
read this
https://honda-tech.com/zerothread?id=1676914
Old Jan 15, 2007 | 10:38 AM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolAssassin &raquo;</TD></TR><TR><TD CLASS="quote">I understand that it is because of the the piston valve lash. </TD></TR></TABLE>
What?
Anyway, i built an all OEM bottom end LS/V a year or two ago that made around 214hp on CAT's dynapack and has last over 20k before it was pulled in favor of going bigger.
Old Jan 15, 2007 | 10:39 AM
Default Re: Would a stock LS/VTEC blow quick? (SkoundrelUSA)
Thanks. I was looking for a good write-up but fell short in the search department.
Colorado_teggy
May 23, 2015 10:50 AM
92hondaswap
Jun 26, 2008 02:43 PM
aznboi88
Mar 17, 2008 03:33 PM
KustomCrx
Oct 24, 2004 12:09 PM
