Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 EX... convert rear drums to disk.
Old Jan 15, 2007 | 08:25 AM
1nicegsr's Avatar
Default 02 EX... convert rear drums to disk.
i want to convert my drum brakes to disk. anybody know what cars i can take the parts off of to convert, and what parts do i need to change other than the drum brakes. thanks
Old Jan 15, 2007 | 08:35 AM
OSK Automotive's Avatar
Default Re: 02 EX... convert rear drums to disk. (1nicegsr)
http://www.civicforums.com/for....html
Provided by Hondaluver
Im sorry but i just have to vent about what people think they can do with their brakes.
Every other day somebody posts how to do the rear disc brakes. People just do not search, it makes me so mad.
here are some facts about our brakes.
1. to do a rear disc brake conversion you need from ONLY a US 02-03 si: 1. calipers 2. discs 3. spindles(knuckel) 4. e-brake cables from a rsx or si 5. dust covers. (picture below)
2. You cannot move the front rotors to the back.
3. The front si brakes are the same as our front
4. Stop asking what is needed, i already posted everything
5. The rear disc swap is straight up, no cutting what so ever
6. If i just had brakes on a non-ex, I would first upgrade my cars tires, then add a ABS system, then disc pads, then rear discs. With this you will never even need to upgrade ur rotors, unless you just wanna look cool, the bigger calipers will problem make u lose your braking ability.
Old Jan 15, 2007 | 08:43 AM
1nicegsr's Avatar
Default Re: 02 EX... convert rear drums to disk. (MisterFrankieJ)
you should add to that, a porportioning valve, and if you find a ex with rear brakes, they would work too. but thanks for the parts listing
Old Jan 15, 2007 | 08:45 AM
I just copied and pasted but the porportioning valve is mentioned in the link.
Old Jan 15, 2007 | 03:52 PM
Vantage's Avatar
Civic Si ( 2002-2005)
RSX ( if u want 5 lug)
Acura 1.7EL ( if u are in canada like me)
jxhxb
Oct 6, 2007 03:53 PM
hmodel88
Honda Civic (2006 - 2015)
Sep 24, 2007 12:00 PM
95ACCLUDE
Nov 11, 2006 07:32 AM
mandelo
Jun 15, 2004 12:08 PM
