B18C-R my best et.....what do you think?
Old Jan 15, 2007 | 03:50 AM
jdmB18CT-R's Avatar
Default B18C-R my best et.....what do you think?
Ran this weekend and still using a stock clutch and flwheel. Motor is a 97B18C-R.
All motor on 91 pump gas when should run higher octane but not available where I'm from. Launching at 6000RPM. What do you think or how do you think I did? What needs to be done? How much of a time will drop by replacing my clutch?
timing by TSI SYSTEM 2000 Plus
Reaction-----.3400
60 ft-----1.9869
ET@594FT-----7.8849
1/8 ET-----8.4311
1/8 MPH-----82.38
1/4 ET-----13.1529
1/4 MPH-----103.97
Modified by jdmB18CT-R at 5:09 AM 1/15/2007
Old Jan 15, 2007 | 04:16 AM
RICO_'s Avatar
NO MERCY!
Default Re: B18C-R my best et.....what do you think? (jdmB18CT-R)
Good run. What kind of car?
Old Jan 15, 2007 | 04:29 AM
jdmB18CT-R's Avatar
Default Re: B18C-R my best et.....what do you think? (RICO_)
96 civic h/b using M&H race masters
Old Jan 15, 2007 | 05:09 AM
D-Rob's Avatar
Fast car for what it is!
What's the weight with driver, and setup?
Old Jan 15, 2007 | 08:24 AM
esohsee's Avatar
Default Re: B18C-R my best et.....what do you think? (D-Rob)
nice times
Old Jan 15, 2007 | 12:26 PM
jdmB18CT-R's Avatar
97B18C-R
Rage V1 header
Rage CNC manifold
MSD ignition system
MSD billet distributor
Password JDM CF intake system
Maxbore TB
CTR/PCT pistons
Mugen 2 layer gasket
Toda dvsprings and retainers
Toda cam gears
Skunk pro cam shafts
Driver: 195lbs
Car: 96 civic h/b
P28 ecu
HOWS THAT?
Old Jan 15, 2007 | 12:37 PM
esohsee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmB18CT-R &raquo;</TD></TR><TR><TD CLASS="quote">97B18C-R
Rage V1 header
Rage CNC manifold
MSD ignition system
Maxbore TB
CTR/PCT pistons
Toda cam gears
Driver: 195lbs
Car: 96 civic h/b
P28 ecu
HOWS THAT?</TD></TR></TABLE>
nice i almost thought you made that time w/ a stock itr motor haha. they still dont have a dyno or a tuner on guam?
Modified by esohsee at 2:08 AM 1/16/2007
Old Jan 15, 2007 | 12:50 PM
88 rex's Avatar
Rage V1 header
Rage CNC manifold
MSD ignition system
Maxbore TB
CTR/PCT pistons
Toda cam gears
Driver: 195lbs
Car: 96 civic h/b
P28 ecu
C'mon now, you had me thinking you were on a stock motor. I guess those times are decent.
Old Jan 15, 2007 | 01:03 PM
D-Rob's Avatar
Default Re: B18C-R my best et.....what do you think? (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">
C'mon now, you had me thinking you were on a stock motor. I guess those times are decent.</TD></TR></TABLE>
Here in the real world, stock ITR engines don't run low 13's on street tires in EK's.
Rage V1 header
Rage CNC manifold
MSD ignition system
Maxbore TB
CTR/PCT pistons
Toda cam gears
Driver: 195lbs
Car: 96 civic h/b
P28 ecu
Your setup looks very good! Sounds about right.
Old Jan 15, 2007 | 01:14 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, my jaw dropped when I saw that time. Heck in my real world, I'd be lucky to see low 13's on street tires in my EF.
&lt;---High 13's.........very high 13's
&lt;----Sucky drive
Old Jan 15, 2007 | 01:46 PM
D-Rob's Avatar
Yea, my jaw dropped when I saw that time. Heck in my real world, I'd be lucky to see low 13's on street tires in my EF.</TD></TR></TABLE>
I know how it feels.
I haven't seen 13's on street tires yet.
Old Jan 16, 2007 | 12:49 AM
jdmB18CT-R's Avatar
Default Re: B18C-R my best et.....what do you think? (esohsee)
Youre right we dont have a dyno on guam. So yes my car is not really properly tuned PERIOD.....
Old Jan 16, 2007 | 12:50 AM
jdmB18CT-R's Avatar
Im assuming that my car is very capable of 12's once I have my clutch and flywheel. You think so, what are my chances?
Old Jan 16, 2007 | 12:55 AM
jdmB18CT-R's Avatar
A stock ITR/JDM ITR hitting low to mid 13's.....LOL!!!!! I'd love to see that. But a lot of people need to realize that just because they have an ITR doesnt mean their super fast. All they can do is dream. This being said to all the ITR dreamers who know where I'm from and think they are going to have amiracle on the track 1320
Old Jan 16, 2007 | 07:31 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmB18CT-R &raquo;</TD></TR><TR><TD CLASS="quote">Launching at 6000RPM.
60 ft-----1.9869</TD></TR></TABLE>
Launch at 8,000 and your 60's will drop to 1.7-1.8's.
Run 6-10 PSI in your slicks.
Old Jan 16, 2007 | 01:43 PM
jdmB18CT-R's Avatar
Default Re: B18C-R my best et.....what do you think? (b19coupe)
I'm still using my stock civic axles and I havent really burned/heated up my slicks yet? Another major problem is that my stock clutch is badly slipping .
Old Jan 16, 2007 | 01:52 PM
b19coupe's Avatar
Do a second gear burnout and heat the slicks up. Lots of smoke is a crowd pleaser too When you stage, light up your first amber, then creep forward very slowly until you light up the second. Keep a slight preload on the clutch-that is, let it up until you feel it wanting to engage. This is where a two-step is handy, you just put your right foot through the floorboards and let the two-step hold the engine at launch RPM. If you don't have a two-step you have to hold the throttle at your desired launch RPM. When the tree drops, GO! By preloading the clutch you minimize drive line shock and your stock axles will last just about forever.
Edit: Replace your damn clutch first!
Old Jan 16, 2007 | 05:20 PM
1 2 NV's Avatar
i cant believe you would add that todd. lots of smoke burn em till the smoke starts showing.
pleasing crowd
going fast
8k launches.
Old Jan 22, 2007 | 11:05 AM
Eg_TypeR's Avatar
Default Re: B18C-R my best et.....what do you think? (1 2 NV)
wut cams r u running??
pro1 pro2 or pro3??
Old Jan 22, 2007 | 11:15 AM
1 2 NV's Avatar
Default Re: B18C-R my best et.....what do you think? (Eg_TypeR)
if your asking me i ran JUN 3s for the last 6 years then my exhaust cam broke into 5 pieces. now i have the Pro 2s.
Old Jan 22, 2007 | 12:40 PM
Eg_TypeR's Avatar
Default Re: B18C-R my best et.....what do you think? ()
how about jdmB18CT-R.. wut cams r u running Pro1 pro2 or pro3?
BlKjDmCiViCsI
Mar 15, 2005 01:16 PM
RISING SUN RACING
Dec 9, 2002 06:09 PM
91hatchcivic
Aug 7, 2002 05:39 AM
LudeLC
Nov 19, 2001 02:32 PM
Erik_Pb_Foot
Aug 11, 2001 01:44 PM
