Max RPM of ITR with standard ECU
What is the standard rev limit on the ITR? And I mean what is programmed into the ECU not what the needle says!
My APEXi PowerFC comes with an initial setting of 8400rpm is this the same as standard (will be answered by the first question of cause)?
Any proof would be helpful to (if such a thing can be found)
i heard it wuz 8500 fuel cut off and 8400 redline. now that i found the hood release i took off the valve cover and the stock cams look easy to replace, just a few bolts!
yup its just a few bolts... no timing or anythign is required... just a few bolts... Can you open the trunk yet?
william did that vary over the yers? my 97 itr borchure i got off ebay says 8500 fuel cut
OK reason I asked is because at a recent Dyno day someone created peak power at 9200rpm with standard ECU, I think the operator must have dialed in a wrong number somewhere (i.e. mph/rpm ratio presuming the mph is taken off the rollers and the rpm is the calculated)
[to correct mistake]
[Modified by HardHead42, 7:42 PM 5/15/2002]
[Modified by HardHead42, 7:52 PM 5/15/2002]
yep, i found the release thanks to the nice peeps here (not including you)
Peeps are the marshmallow chicks that are sold around easter time.
Peeps are not people.
8,400rpm is indicated is the red line.
The normal rev limit using a VAFC to look at the highest humber = 8590-8610 rpms...
Will
hmm i guess i'll check the brochure again but im 99% sure its 8500 according to acura.
b-diddy: peeps are good and tasty, just like women peeps, but then you probably dont have experience there
Actually you are incorrect.Peeps are sold year around at any reputable retail outlet.
Wow dude. You really zinged me there... If I didnt know you were already 17 I would have guessed that... The best "insult" you little kids can come up with is a lame attempt at making fun of my sex life, which you have no idea about and neither does anyone else here. I keep that personal because I am a gentleman. And I, unlike you, have a level of respect for women.
Now go away or I shall taunt you a second time!
actually you clearly said "are sold around easter time." which does not equal "are sold year round but i never see them for some reason". and that's for proving my point on the chick thing, but hey, it's cool if you have an alternative lifestyle, thats your business i wont hate you because of it.
You might want to learn how to READ instead of ASSUME. Sold around Easter time does not equal ONLY sold around Easter. Read the post. If I wanted to say sold only around Easter I would have said so. They are sold in abundance(thats a college word for alot) aroudn Easter.
Once again an immature attack on my suposive sexuality of which you have no knowledge. I really hope that whatever career you choose(Mickey D's fry guy sounds best. Maybe if you work hard enough you can become assistant manager.) you dont have to use reason or proofs. You wont last a week...
