adjusting valves after installing cams...
Do I use the OEM spec or do I have to adjust the valves? I'll be using skunk2 stage 2 cams. If i need to adjust the valves, what are the numbers? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">0.007" and 0.008". Adjust the valves after any cam change.</TD></TR></TABLE>
that is in inches correct or millimeters???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 »</TD></TR><TR><TD CLASS="quote">that is in inches correct or millimeters???</TD></TR></TABLE>The little " denotes inches. mm is how millimeters are normally expressed.
0.007"~0.17mm and 0.008"~0.19mm.
b20_driven
Aug 10, 2008 01:45 PM
b20_driven
Aug 5, 2008 01:12 PM
