VTEC not working?please help
Old Jan 14, 2007 | 10:16 PM
ALLmotorTYPES's Avatar
Default VTEC not working?please help
I own a 02 RSX S and I notice that vtec will not kick in first gear, but kicks in 2nd gear. Whats wrong? Also will it hurt the motor if I take it to high rpm's with vtec not working?
Old Jan 14, 2007 | 11:12 PM
Default Re: VTEC not working?please help (MyliTTLeDc5)
anyone?
Old Jan 15, 2007 | 12:09 AM
inkong's Avatar
im not sure what is wrong with your vtec ... but i dont think it hurts your car when your not in vtec at high rpms
Old Jan 15, 2007 | 12:03 PM
s2k_3.11's Avatar
Check your oil level / pressure.
Check your solenoid.
Old Jan 15, 2007 | 02:22 PM
DonReggeaton's Avatar
is your engine light popping up?
Old Jan 15, 2007 | 03:14 PM
Default Re: VTEC not working?please help (DonReggeaton)
No the engine light is not on. But I'm going to autozone and run there tester to see if there is a code.
Old Jan 15, 2007 | 04:40 PM
fool11's Avatar
Doesn't VTEC kick in only when you're above 25 or 35 mph? I'm not 100% sure on that though. But I think that is what's happening since you say it won't engage in first gear, but will in 2nd gear and on...
Old Jan 15, 2007 | 05:08 PM
Default Re: VTEC not working?please help (fool11)
Well I just added two quarts of oil cause it was low. After that I ran it a few min and vtec was working again. Any idea's why it would do that? also has anybody experience oil burning with there rsx/ep3 k20?
Old Jan 15, 2007 | 06:27 PM
well no man not at all mine is a 04 no burning oil and about the vtec thing well seems weird, when u went to auto zone did they told u about a code or something?
Old Jan 15, 2007 | 09:10 PM
No, there was no codes.
Old Jan 15, 2007 | 11:01 PM
k20EP3's Avatar
you should do some reasearch about Vtec and learn how the motor works. you need the right amount of oil in the engine because if its low you don't get the right amount of pressure to ingage the Vtec pin. so in other words oil is what kicks on the solenoid to engage the vtec
Old Jan 16, 2007 | 09:37 AM
Default Re: VTEC not working?please help (k20EP3)
for me it sounds like u have oil problems u say your car is burning oil and that when u put on more oil the vtec started working again. have u been reving high your car?
Old Jan 16, 2007 | 10:16 AM
I rev it high a couple time a week nothing major. Should I be worried about this problem?
Old Jan 16, 2007 | 02:07 PM
well the k series is meant to be for reving high but if ur all stock i highly recommend u not to, u dont want to mest u ur internal **** and then u would have a problem
Old Jan 16, 2007 | 04:33 PM
hcvc05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonReggeaton &raquo;</TD></TR><TR><TD CLASS="quote">well the k series is meant to be for reving high but if ur all stock i highly recommend u not to, u dont want to mest u ur internal **** and then u would have a problem</TD></TR></TABLE>
what???? why?
Old Jan 16, 2007 | 09:54 PM
eMpAtHy's Avatar
Default Re: VTEC not working?please help (hcvc05)
if your oil was low enough to where you needed 2 quarts and you were revving the **** out of it, expect it not to last long. running on 3 quarts and beating the **** out of it is pretty damn bad.
Old Jan 16, 2007 | 10:10 PM
Mediademics's Avatar
Not to be cruel but if you don't know enough about cars to check your own oil then you better not be beating on your car because if you break something your going to be up ***** creek. Unless you just have the extra money to be replacing your motor.
Old Jan 17, 2007 | 06:46 AM
see i told you ! better take start taking care of your car man if not thats it for your baby!
Old Jan 17, 2007 | 09:07 AM
.Kevin.'s Avatar
So how do you know it's kicking in in 2nd gear? Granted the crossover is so smooth you don't feel a kick.
Old Jan 17, 2007 | 02:10 PM
Default Re: VTEC not working?please help (Ep_Kevin)
To set the facts straight, I do take care of my car! I change my car's oil every 2500 miles,engine tuned,baby it, and keep it clean etc... It's a newer car and I should not have to be worried about it burning oil so soon! I only had this car three month's and I'm having to deal with this problem. All I want to do is figure out this problem and fix it!
Old Jan 17, 2007 | 02:16 PM
When it kick's in 2nd gear it's normal. It doesnt feel weak or slow. It only did that one day before I check the oil.
Old Jan 17, 2007 | 04:23 PM
what year is it and how many milleage does it have if your not the first onwer maybe the first one rev the **** out of it,
Old Jan 17, 2007 | 06:03 PM
There was one owner, he was in high school when he got it. When I bought it, it had 82000k on it.
Old Jan 17, 2007 | 06:05 PM
91integra0746's Avatar
Default Re: VTEC not working?please help (inkong)
i have a 91 integra im tring to run ls/vtec.....but my vtec is not working....i have enough oil....i ran my vtec wires......i have power to both the solonoid and the pressure switch...and its still won't kick on......can anyone help me
Old Jan 17, 2007 | 06:50 PM
.Kevin.'s Avatar
Default Re: VTEC not working?please help (91integra0746)
I vtec does not kick. I have driven an rh/e/cai rsx and a kpro'ed rsx and in neither of them did the car have a "kick"
You also are wasting money changing your oil every 2500 miles just for future refferance.
