tig... day 2
Old Jan 14, 2007 | 08:27 PM
dmotoguy's Avatar
Default tig... day 2
here is my second day welding mild and stainless, my brother is a welder and was giving me lots of tips.. wanted to see if you guys have any as well.
miller 185sd, ~60amps 20cfm
Old Jan 14, 2007 | 08:46 PM
SequenceGarage's Avatar
Default Re: tig... day 2 (dmotoguy)
looks great dude
between that top weld and the lower weld in your second picture what did you do to improve the color of the weld?
Old Jan 14, 2007 | 09:31 PM
dmotoguy's Avatar
Default Re: tig... day 2 (SequenceGarage)
the color was the same.. i used a scotchbright pad on the bottom and it made it silver so you could bearly see there was a weld there.
Old Jan 14, 2007 | 11:43 PM
RC000E's Avatar
Looks heavily undercut in some areas. Also, don't see much of a bead profile. In all honesty though, the pic is just too far away to really say much about it. The metal has a strange surface to it, so it adds to the difficulty. What does your penetration look like from the inside?
Old Jan 15, 2007 | 12:10 PM
TurboSI56's Avatar
Default Re: tig... day 2 (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Looks heavily undercut in some areas. Also, don't see much of a bead profile. In all honesty though, the pic is just too far away to really say much about it. The metal has a strange surface to it, so it adds to the difficulty. What does your penetration look like from the inside?</TD></TR></TABLE>
It looks like it's just a fuse weld. But looks like a good start
Old Jan 15, 2007 | 05:01 PM
Sims's Avatar
I was going to say the same thing. Very undercut in some areas. Either you are using no filler material or you are using a very thin gauge and not enough. Looks good for just getting started.
Old Jan 15, 2007 | 06:33 PM
dmotoguy's Avatar
Default Re: (Sims)
this was done with very little filler.. i'll post some new welds up later.. I think the pictures make it look more undercut than it is on the right side though.. the center is even or a little above.
Plum_civicEK
Jun 19, 2007 02:54 PM
jason DB8
Aug 18, 2006 07:09 AM
rasinhell
Aug 22, 2005 03:25 PM
Layziebtnh055
Jun 3, 2004 12:13 PM
thelucysong
Jul 21, 2003 07:06 AM
