What to use to drill
Old Jan 14, 2007 | 07:59 PM
Del Sol on Steroids's Avatar
Default What to use to drill
carbon fiber, i need to drill holes for hood locks
Old Jan 14, 2007 | 08:00 PM
Hondizzle!'s Avatar
Default Re: What to use to drill (Del Sol on Steroids)
a drill and a drill bit Put some masking tape on the hood where you are going to drill and drill THROUGH the tape and hood at the same time... this will HELP prevent splintering.
Old Jan 14, 2007 | 08:03 PM
MidwestSiR's Avatar
AND: start with a small if not tiny bit and work your way up the size chain!
Old Jan 14, 2007 | 08:04 PM
Hondizzle!'s Avatar
Default Re: (MidwestSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR &raquo;</TD></TR><TR><TD CLASS="quote">AND: start with a small if not tiny bit and work your way up the size chain!
Old Jan 14, 2007 | 08:05 PM
Default Re: What to use to drill (Hondizzle!)
Any type of drill?
Old Jan 14, 2007 | 08:06 PM
Default Re: (Hondizzle!)
Old Jan 14, 2007 | 08:07 PM
MidwestSiR's Avatar
as long as it's powerful enough to drill through plastic
Old Jan 14, 2007 | 08:08 PM
Nice, didnt want o messed it up with titanium
Old Jan 14, 2007 | 08:09 PM
MidwestSiR's Avatar
like i said... start small and keep working your way up and up..
you'll be fine
Old Jan 14, 2007 | 08:44 PM
.:Made in OC:.'s Avatar
use a sharp drill bit and a normal drill. Remember to mask it and drill through the masking tape on both sides. You shouldnt have any problems, i just drilled some holes through canards couple days ago.
Old Jan 14, 2007 | 09:00 PM
VRD^don's Avatar
Default Re: (Made In OC)
use a step bit
Varao
Oct 5, 2006 02:29 PM
mildly.interesting
Oct 8, 2003 09:50 PM
S13 slide
Jun 2, 2003 07:28 AM
TeamTooQuick
Apr 20, 2003 06:39 PM
Double 06
Mar 28, 2003 11:03 AM
