dohc zc dizzy making loud squeal
Old Jan 14, 2007 | 04:35 PM
freshly boosted DOHC ZC's Avatar
Default dohc zc dizzy making loud squeal
well like always when i start my car for the first time i let it warm up for a few min. but today after it was warmed up i noticed my dizzy making a really high pitched squeal. it first started to do it off and on and after about 2-3 min later it was a constant high pitched squeal and almost sounded like it got louder. any idea on what it could be?
thanks in advance
Edit: no codes what so ever
Modified by almost boosted DOHC ZC at 6:45 PM 1/14/2007
Old Jan 14, 2007 | 06:03 PM
Default Re: dohc zc dizzy making loud squeal (almost boosted DOHC ZC)
bump.
come on guys. is my distributor going bad? need to know this is my only way of transportation
asked my friends none of them know either.
Old Jan 14, 2007 | 06:08 PM
Crx Jimmy's Avatar
Its probably the bearing in the dizzy going out I have in the past took the cap off and used a syringe and put a small amount of oil on the bearing and it would quite it down for awhile but its just a band aid it will fail sooner or later(if this is the problem) to check take the cap off and grab the rotor if you can wiggle it back in forth at all even like 1mm the bearing is bad
Old Jan 14, 2007 | 06:09 PM
fireant's Avatar
Yes, this is the tell-tale sign of the bearings going out in the dizzy. Google search for distributor king to get a good deal on a new one pronto!
Old Jan 14, 2007 | 06:23 PM
Default Re: dohc zc dizzy making loud squeal (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Yes, this is the tell-tale sign of the bearings going out in the dizzy. Google search for distributor king to get a good deal on a new one pronto!</TD></TR></TABLE>
yeah every one says distributor king is the way to go. and since its going out mine as well switch to obd1 distributor for turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Its probably the bearing in the dizzy going out I have in the past took the cap off and used a syringe and put a small amount of oil on the bearing and it would quite it down for awhile but its just a band aid it will fail sooner or later(if this is the problem) to check take the cap off and grab the rotor if you can wiggle it back in forth at all even like 1mm the bearing is bad</TD></TR></TABLE>
thanks for the useful info. wouldn't hurt to run the engine with the distributor how it is would it?
hasty91ef
Sep 20, 2010 04:54 PM
cmyrex
Sep 25, 2005 03:26 PM
gutted-dx
May 15, 2005 04:42 PM
crxdevelop
13
Mar 11, 2003 10:32 AM
CWBETB
Aug 26, 2002 06:50 AM
