What kind of damage can a broken Sperpentine belt do? 5th gen
Old Jan 14, 2007 | 12:29 PM
justint's Avatar
Default What kind of damage can a broken Sperpentine belt do? 5th gen
My serpentine belt on my 5th gen shredded today. I am a bit irritated as it is only about 10k miles on a fresh belt. I was actually on my way to the shop to have that checked out as it has been making noise for a bit now when it gave, taking out another belt with it. My power steering was out, alternator belt was gone, check engine, atts, and brake light on....much fun.
Is this likely to have caused serious damage?
Old Jan 14, 2007 | 12:39 PM
preludeguy_92's Avatar
Default Re: What kind of damage can a broken Sperpentine belt do? 5th gen (justint)
you should be ok
Old Jan 14, 2007 | 12:45 PM
justint's Avatar
Default Re: What kind of damage can a broken Sperpentine belt do? 5th gen (preludeguy_92)
I am hoping so..this might be a time to put lighter UR alternator and power steering pulleys on though.
Old Jan 14, 2007 | 01:06 PM
117's Avatar
117
The 5Gen does not have a serpentine belt. The alt/AC belt is separate from the PS belt. If you didn't damage timing belt, then you probably didn't damage the engine.
Old Jan 14, 2007 | 01:13 PM
ninja 6's Avatar
Default Re: (117)
you didnt damage anything important
you did however probably drain your battery, and your steering was probably hard as **** to steer.
they're still called serpentine belts, fyi
I wouldnt worry about it. i'd recharge your battery and replace those belts asap with the gatorback poly v.
Old Jan 14, 2007 | 01:23 PM
117's Avatar
117
Well, the alt/AC belt is technically a serpentine belt, I suppose. The PS is not.
Old Jan 14, 2007 | 01:53 PM
bluedlude's Avatar
Default Re: (117)
"accessory" belt. and depending on what happened, it could have caused some serious damage. your timing belt could be broken as well and unless youve taken the valve cover off, you wouldnt be able to tell.
M.D. CIVIC
10
Feb 23, 2010 06:47 PM
HondaH22a#1
Jun 29, 2007 08:27 AM
d8168055
Oct 5, 2002 06:59 PM
stRtypR25
Sep 15, 2002 07:43 AM
PorscheGT2
Dec 18, 2001 01:17 PM
