Leakdown Testing F.Y.I.
Old Jan 14, 2007 | 11:13 AM
NICEHATCH's Avatar
Default Leakdown Testing F.Y.I.
L
Modified by NICEHATCH at 6:39 PM 7/20/2008
Old Jan 14, 2007 | 12:04 PM
bart2546's Avatar
Default Re: Leakdown Testing F.Y.I. (NICEHATCH)
Great information, that's for the write up, bookmarked for sure. Sticky vote from me.
Old Jan 14, 2007 | 12:32 PM
Flashmn's Avatar
Default Re: Leakdown Testing F.Y.I. (bart2546)
I dont see how the fuse would have to be pulled if you keep the ignition off, the ECU shouldnt have power nor would the fuelpump, so you could freely just turn the engine without having fuel injected.
Old Jan 14, 2007 | 01:01 PM
Eddiebx's Avatar
i think u have a leak down test confused wiht a compression test if your pulling out the fuse to do a leak down test
Old Jan 14, 2007 | 09:33 PM
snowseeker's Avatar
Default Re: (Eddiebx)
And sometimes you have to turn the motor over a bit to close the valves in the cylinder.
Old Jan 18, 2007 | 01:09 PM
Flashmn's Avatar
Default Re: (snowseeker)
true, but since your key will be in the off position, the ECU wont get power, nor will the injectors, so taking out the fuse wouldnt do anything. Plus you probably wont be turning it with the starter either, as its very unprecise, you're gonna turn it from the crank pulley bolt with a spanner.
Old Jan 28, 2007 | 10:20 PM
swtslvrmonkey's Avatar
Default Re: (Flashmn)
Suggestions as to where to buy a leak down test tool for a good price?
Gobiee
May 18, 2016 09:27 AM
xJDMCx
May 29, 2009 06:10 PM
elmejor
Nov 6, 2008 11:57 AM
cvclover
Feb 25, 2007 06:43 AM
DC4_MADMAN
11
Jul 6, 2005 06:10 PM
