Fog Lights
Alright so I picked up some fog lights and I have them on the car and all, now I just need to know where would be the best place to tap into for some power? What would be the easiest way to power the fogs? I have a 98 Honda Accord Coupe V6. Thanks in advance.
Ideally, you would want a switch to energize a relay that would power the fogs. Otherwise you would need to run heavy gauge wires to a heavy duty switch that is rated for at least what the lamps will draw. Fuse the circuit as required.
