Got Oil in My Coolant
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arren123 »</TD></TR><TR><TD CLASS="quote">Ok.. I pulled my head this Saturday, but a ton of oil dripped into my coolant.
How do I clean and drain it from there ?
Simply drain the coolant like you would if there wasn't oil in it. You may need to run some kind of cleaner through the cooling system once you have it all back together.
If you want to do it the fast way, take off the radiator cap and pull the lower radiator hose off. Watch your toes.
</TD></TR></TABLE>Simply drain the coolant like you would if there wasn't oil in it. You may need to run some kind of cleaner through the cooling system once you have it all back together.
skunk2finatic
Dec 16, 2004 02:46 PM
hybridb18
Aug 6, 2003 09:00 PM
