b18a using a PM6,PR4,PM8,PM5?
Old Jan 14, 2007 | 09:07 AM
harmonator84's Avatar
Default b18a using a PM6,PR4,PM8,PM5?
The crx I just bought has a b18a and came with two ecu's.
A PM6"crx si" and a PR4"intergra LS". I am currently running the PM6 in the car because it will give me alittle better mpg.
Now I also have a PM8"crx hf" and a PM5"crx dx".
The question I have is that what would happen if I use the PM8. Would I get better mpg but the car would run like half its potential?
Another question is that a PM5 is not set up for mpfi so it wouldnt work...right?
Old Jan 14, 2007 | 09:18 AM
zccr-xsi's Avatar
why arent u seing the pr4 for the ls motor?try pm7 from dohc zc and see what happens
janz3n's Avatar
Default Re: b18a using a PM6,PR4,PM8,PM5? (harmonator84)
i didnt know pm6 works on a b18.. i guess it would though.. pm5 is a dpfi ecu for d15b2 so no that would not work at all. search for the correct ecu to use.
Old Jan 14, 2007 | 09:20 AM
dr_latino999's Avatar
Default Re: b18a using a PM6,PR4,PM8,PM5? (janz3n)
You realize it takes more then just the ECU to increase fuel mileage, correct?
Old Jan 14, 2007 | 09:22 AM
crxnj's Avatar
Use the PR4 ecu..you have it,use it.
Old Jan 14, 2007 | 09:30 AM
zccr-xsi's Avatar
Default Re: b18a using a PM6,PR4,PM8,PM5? (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Use the PR4 ecu..you have it,use it. </TD></TR></TABLE>
words of wisdom
Old Jan 14, 2007 | 10:32 AM
Default Re: b18a using a PM6,PR4,PM8,PM5? (zccr-xsi)
I was going to but he said it is chipped for a turbo.
I am able to still use it but it gets horriable mpg.
Nooch
Nov 11, 2011 03:27 PM
strawberry
10
Dec 14, 2007 11:47 AM
O16581724 5 2 5
10
Jun 7, 2006 11:19 AM
Beetle
Mar 25, 2005 10:39 PM
pinoyboy204
Jul 26, 2003 04:11 AM
