FG COUPE 10" Sidewall Sub Box- Fiberglass------Projekt1
So heres the box i have been working on adn its nearing completion. It just needs the finish sand and paint...Its for Any FG coupe - (dx/lx/ex/si) - but will not fit the sedan FA's. Fits in the driver side rear sidewall flush-mount for a single 10" sub, up to 9" deep. Is roughly 1.2 cu ft of sealed airspace....
the build:
Modified by gentek1145 at 8:17 AM 1/14/2007
the build:
i'm looking to build one for my lx sedan, what exactly did you use to make the mold??
Here is a picture of my current setup
I want to leave them there but mold my box to fit flush with the back seat and only out to the probably half way down the wheel well, want to leave lots of room in the trunk cause right now i don't have a lot left
any thoughts??
good job by the way, looks pretty sweet
any thoughts??
i just lined the sidewall with plastic, taped it up, and started laying the fiberglass inside the trunk.
Once it dried, i pulled it out, and had a complete mold for the trunk's sidewall- then i just dremel trimmed it to the size and shape i wanted the box to fit.
Then i constructed the face of the box.
tada.
tada.
cool....looks pretty sweet, good job on the build, i'm thinking i'm either gonna put one box against the back seats or two boxes molded to the corners like what you built, and do it that way.
thanks for the input man...
these may help also...Heres another build i did awhile back for my homeboy's integra 4door.---
btw- someone may want to archive these in to the HOW-TO's or something like that for future reference...thats cool.
finished product---minus paint again./
it depends on how much hardener you use. I always use more than the directions say becuase it just dries faster...My molds usually take about 30-60min. to dri before i can remove them. It will take longer if you dont add enough hardener....I have seen it take as long as 2-3 days (when i was experimenting with fiberglass)....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gentek1145 »</TD></TR><TR><TD CLASS="quote">yeah, all the boxes i build with the intent to easily remove them if need be (to access the spare, or go to the race track)..etc.</TD></TR></TABLE>
So how is the box secured inside the trunk then? Is it molded in a way that its a nice snug fit into the side, or is it bolted down or something?
yeesiiir. I could easily make one.
x2: It is an EXACT MOLD of the Driver's sidewall trunk liner. Fits Perfect. 2nd, I have security bolts that can be installed to make it not easily removable.
Cool. So it's a pressure fit box? No bolting needed? That would really come in handy.
gentek1145 very nice work
any chance to make like the square for like the kicker L5 12's? oh and a good ideal is to do a dynamat because damn the car rattles alot from the outside ( 2dr civics im speaking of )
lgchristianson
Audio / Security / Video
May 31, 2007 01:27 PM
