What diameter of Washer used for a Prelude LMA Swap in a B series?
Old Jan 13, 2007 | 10:29 PM
95vteg's Avatar
Default What diameter of Washer used for a Prelude LMA Swap in a B series?
Hey I picked up some washers that are just a tad bit thicker then .040 for my H22 LMAs that I will be installing in my b18c. The ones I ended up buying are a little small for the bores and they move around a little more then I would like in the bores. I'm not sure if this is a big deal so I would just like to know what diameter washers people have been using as shims for their LMAs?
Old Jan 14, 2007 | 08:17 PM
95vteg's Avatar
Anyone have the exact measurements of the washers they used with their H22 LMAs. I know it's supposed to be .040" thick but what should the diameter be???
Also has anyone noticed that the H22 LMAs don't fit as tight in the bores as the normal B series ones. Does anyone know if this is anything to worry about???
Old Jan 16, 2007 | 08:00 PM
95vteg's Avatar
Default Re: (95vteg)
Bump because no one on here is helping me out when I know damn well someone knows the answer. I would also like to know if I used a slight thicker washer measuring in at .053" if that would be a problem. I think it'll be alright since their only being used with cams that have a 10.5 mm lift but I would like to know from other people what they think.
Old Jan 16, 2007 | 08:06 PM
mgags7's Avatar
why don't you search the archives? this has been covered before
Old Jan 16, 2007 | 08:15 PM
95vteg's Avatar
Default Re: (bb4ever)
All I ever find when I search is the thickness of the washers not the diameter. The only washers I found thin enough were very small in diameter. The only ones I found big enough to fit nicely into the bores are .053" or so thick. So I don't know if this would be acceptable for a cam with such a low lift as 10.5mm.
jeremy.
244
Sep 15, 2007 10:07 AM
joshualynn07
Aug 11, 2006 11:43 AM
burplelude
Jun 9, 2006 10:40 AM
VegasEFHB
48
Jan 25, 2005 08:02 AM
funkfnamna
May 6, 2004 11:08 AM
