Brake light?
Old Jan 13, 2007 | 10:00 PM
TXGrunt's Avatar
Default Brake light?
Anybody ever have there brake light on the gauge cluster just come on for no particular reason??? I do think something happened when I had to slam on my brake cause somebody in front of my just decided to turn with no turn signal and I had to "slam on my brakes" Well after that I noticed that when I make sharp right turns that my brake light on the gauge cluster will come on!!! I still have brake pressure when I put my foot on the brake pedal and the car stops fine. I'm just trying to figure out what can be causing this???
Old Jan 13, 2007 | 10:42 PM
MidwestSiR's Avatar
mine did this... it's the sensor .. it's either gone bad or you need to reset your parking brake.
just loosen up slack in the e-brake lines(right by the lever) jack up the car in the rear spin the tires and start adding tension via turning the bolt on the ebrake lines.
that fixed my problem
Old Jan 13, 2007 | 11:20 PM
BlueIntegraBoy's Avatar
Default Re: Brake light? (TXGrunt)
Check your brake fluid level
Old Jan 13, 2007 | 11:59 PM
jadugartir's Avatar
Default Re: Brake light? (BlueIntegraBoy)
the light is controlled by that thing that floats in ur brake fluid reservoir.
When u slammed on the brakes, the sensor must have moved temporarily so u might be a bit low on fluid. if it were full it probably wouldnt have moved the sensor much.
Old Jan 14, 2007 | 09:29 AM
TXGrunt's Avatar
Default Re: Brake light? (jadugartir)
Thanks all I will take a look at that this week!!!
Old Jan 14, 2007 | 09:57 AM
Hybrid-Fusion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Check your brake fluid level</TD></TR></TABLE>
X2
jdm.coupe3234
15
Jan 22, 2010 12:57 PM
Fly1865
Jul 28, 2005 02:03 PM
EuRoBrO
Dec 1, 2003 01:32 PM
civicboisi
Mar 8, 2003 06:45 AM
94BlackRS
Nov 28, 2002 02:43 PM
