Clutch Noise
Old Jan 13, 2007 | 09:36 PM
actionfigure's Avatar
Default Clutch Noise
I get a grinding noise when I shift it in reverse.
When Im driving in reverse its good. No noise, only when I shift the stick back.
Not with anyother gears.
Old Jan 13, 2007 | 09:37 PM
B18CivicEH2's Avatar
Default Re: Clutch Noise (actionfigure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by actionfigure &raquo;</TD></TR><TR><TD CLASS="quote">I get a grinding noise when I shift it in reverse.
sounds like its your tranny and not the clutch..
Old Jan 13, 2007 | 09:42 PM
Default Re: Clutch Noise (B18CivicEg)
ok thanks.... is it a big problem or just a quick fix?
Old Jan 13, 2007 | 09:44 PM
Zeusfire69's Avatar
Try this...press in your clutch, put it first gear first (this will stop the trans from spinning), then put it in reverse. This is the way you are supposed to put it in reverse. Reverse is NOT sincronized in that transmission. If you do not let the transmission stop spinning first (push in the clutch, wait a second, then go to reverse) it will grind going in. This car (transmission) would have made a grind going into reverse right off of the showroom floor if you pushed in the clutch and jammed it into reverse. There is NO problem with your clutch or your transmission. Try it with any other interga or civic...that's proof.
Old Jan 14, 2007 | 01:49 AM
Default Re: Clutch Noise (Zeusfire69)
Interesting. I never knew that.
So I have to put it into first then reverse or press the clutch and wait for a second and then reverse?
Old Jan 14, 2007 | 05:10 AM
Mikes2000civicsi's Avatar
yup had the same thing....ur not the only 1......1st to rev
VTi NA
Aug 18, 2021 02:02 PM
JustEFit
Jun 23, 2013 06:22 PM
J-Willz
Honda Civic (2001 - 2005)
Jul 24, 2007 08:24 PM
CDN Yellow ITR
Feb 10, 2005 02:38 PM
95 silintegra
Oct 3, 2003 05:46 AM
