For sale 2000 JDM ITR complete engine swap w/ Hondata S200 and P28 ECU
I'm selling a complete 00 JDM ITR for a friend in good/mint condition. Bought it from Hmotorsonline "Steve" and have aprox. 45k miles on it. The motor is in a 2000 Civic SI right now and will pull the motor out if someone is interested on buying it. We also include the Hondata S200 blue box and P28 ECU. The motor is very strong and some locals don't believe it is completely stock. So someone paid the get it dyno tested to see if indeed a stock motor. The motor put 180whp on the dynamic dyno here in Stage 6 in Jacksonville and 177whp on the dynojet at Velocity Trend also in Jacksonville. The dyno pull were taken in different days. After the pull, everybody were shock how the motor is very strong. This is not a tuned motor yet as it's using only the base map.
So, You get the motor, tranny w/ LSD 4.7 final ratio, shift linkage, P28 socketed ECU and Hondata S200. No wire harness. The old motor mounts were not use in the swap because it has some bad bushing in them. We use the Hasport motor mounts instead. The engine have a brand new timing belt and water pump before we install it into to SI.
Price for the complete motor swap w/ tranny, shift linkage, P28 socketed ECU and Hondata S200 box is $4400 + shipping and handling
w/o the P28 ECU and Hondata S200 $4100+ shipping and handling.
Please email me at r.adona@comcast.net or PM me for more info. Thank you for looking. Please NO LOW BALLER.
Modified by V-SPEC 1 at 12:30 AM 1/14/2007
Modified by V-SPEC 1 at 9:34 PM 1/14/2007
Modified by V-SPEC 1 at 12:45 AM 1/15/2007
00zzySi
Nov 12, 2009 06:49 PM
t-blizzard
Aug 30, 2004 11:15 PM
12secEG
Mar 23, 2004 07:30 PM
Seye
16
Oct 24, 2003 07:25 AM
