exhust question
Old Jan 13, 2007 | 08:10 PM
19992civichatch's Avatar
Default exhust question
i have a 3 inch stright pipe is that bad for the motor? should i look to put a cat on or not?
Old Jan 13, 2007 | 08:11 PM
deadline's Avatar
Default Re: exhust question (19992civichatch)
dude put a cat on your causing global warming..
Old Jan 13, 2007 | 08:13 PM
allricedout's Avatar
^^^ then you will only be charged with animal abuse^ lol
Old Jan 13, 2007 | 08:19 PM
ok i understan that im hurting the world lol but is my motor being hurt with no back pressure it came with the car
the car is a b20vtec cams header the whole head is worked clutch flywheel throttle body and soem other **** i cant think of right now
Old Jan 13, 2007 | 08:24 PM
krazyhmongboi's Avatar
what mods does ur car have? like 10 second motor?
Old Jan 13, 2007 | 08:27 PM
Syndacate's Avatar
Default Re: (19992civichatch)
You're fine.
You won't see any HP gains from it b/c your exhaust isn't creating enough power out of such a small displacement that you need a wider exhaust to handle the back pressure. On the flipside, seeing as the piping before and after the test pipe is 2.25 (stock, I'm assuming) you'll maintain back pressure just fine.
JDM Roc
11
Apr 30, 2009 04:48 PM
8_6 luder
Jun 29, 2007 09:02 PM
19992civichatch
16
Feb 28, 2007 07:44 PM
99BlackHatchSiR
Jun 26, 2006 02:56 PM
jansenrw
Jun 20, 2003 01:25 PM
