Pulled a few things and now car wont start
I pulled my ac compressor with all components , the cruse control , power steering compressor,( looping the lines and removing a few) , and the driver side fan . I also pluged any vaccum lines left open from the removal of the other componets . I just changed my plugs ( Denso Iridium's ) . Everything was fine until now . Any ideas on the what could be wrong ?
Checked and both are good. I just hope I dont end up having to return any of that crap back .The bays alot cleaner and the car's alot lighter . I have to lower it again, lol
do you have 12 volts at the battery? check the cruze wires one of those goes to the dist and tac i believe... also do you have voltage going to your dist? im sure something very simple youve overlookd break a leg with that,,,jt
I found the problem . It turns out that theirs a little switch under the dash that resets the fuel pump. Thats all I needed. Thanks alot for all of your replys. And for the plugs . I thought the Denso Iridium's were supposed to be better than the Ngk Iridium's , they cost a hell of alot more and their the only ones of the two that I ever see advertised. I thought the ngk's were the knock off version , but i've used them before and they were great , havent driven with the denso's yet though.
7rrivera7
Sep 16, 2006 05:19 PM
Woody_geeser
Aug 23, 2001 05:42 PM
