vss help
Old Jan 13, 2007 | 05:09 PM
russianswty's Avatar
Default vss help
Ok so ive got a 89 ef si with a gsr and the speed sensor that came with the tranny has
two lines for oil or something, while my si has nothing, which one should I be using,
And yes I am using my stock speedometer, cable driver which both of the sensor's are
cable driven.
And what are those oil lines for?
Old Jan 13, 2007 | 05:26 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: vss help (russianswty)
just loop them together you won't need it
Old Jan 13, 2007 | 05:39 PM
Default Re: vss help (HondaPartsHero)
what is the purpose of that? is it supposed to keep the gears lubbed up?
should I put some gear oil or engine oil in there before hand and do I want
to loop them or just plug them up?
Old Jan 13, 2007 | 07:54 PM
salman's Avatar
they are looped from factory,
Old Jan 13, 2007 | 08:35 PM
Default Re: (salman)
ok can anybody be a little more specific,
Old Feb 4, 2007 | 08:07 PM
cryptikguy's Avatar
i think one side is for the power steering pump and the other is for the power steering rack. so one is in and the other is out. just hook them up together with power steering fluid inside
rumo1112
Jan 31, 2011 09:42 AM
xero-cool
May 22, 2006 08:42 AM
AccordRacing
Jun 8, 2005 05:04 AM
soon2b
Jul 11, 2004 02:28 PM
hurleyburley
Jul 24, 2002 01:53 PM
