True or False
Old Jan 13, 2007 | 10:33 AM
aaronISthrowed's Avatar
Default True or False
I herd from someone today that its not good to leave a car outside when its cold and on a very low tank of gas.
Is this true or false?
Cold being below freezing.
Old Jan 13, 2007 | 10:50 AM
garyb's Avatar
i left my car outside with almost empty tank and my car wouldn't start. once i filled it from my jerry can it started fine...?
AllMotorDan's Avatar
why would you want to have a very low tank of gas in the first place. im sure it doesn't help the car but maybe he thinks the gas will freeze or something. i guess you gotta know the freezing point of gas?
Old Jan 13, 2007 | 10:52 AM
Default Re: (AllMotorDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDan &raquo;</TD></TR><TR><TD CLASS="quote">why would you want to have a very low tank of gas in the first place. im sure it doesn't help the car but maybe he thinks the gas will freeze or something. i guess you gotta know the freezing point of gas?</TD></TR></TABLE>
It's not my car, i keep mine in the garage
I was just courious.
Old Jan 13, 2007 | 11:11 AM
Boots's Avatar
Default Re: (aaronISthrowed)
the freezing point of gasoline is well below 100 degrees farenheit....but if there is water in the gas then that is a different story
Old Jan 13, 2007 | 02:02 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (boots)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">I herd from someone today that its not good to leave a car outside when its cold and on a very low tank of gas.
Cold being below freezing.</TD></TR></TABLE>
ROFL. You warm weather people.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">the freezing point of gasoline is well below 100 degrees farenheit....but if there is water in the gas then that is a different story</TD></TR></TABLE>
I've had a car with some water in the tank pack the fuel filter with ice crystals. The level of the tank doesn't matter, as water will sink to the bottom.
jdmeg6118
15
Aug 27, 2008 07:35 PM
1kleenef
10
Oct 22, 2007 06:30 PM
urafag
Jun 30, 2006 05:07 AM
1sikhatch
57
Mar 11, 2005 04:36 PM
adaml2nv
Jun 6, 2004 04:50 AM
