brake light!!
Old Jan 13, 2007 | 08:32 AM
donnybrook's Avatar
Default brake light!!
ok so im not sure whats goin on if its just a sensor or what but heres the deal.
im driving yesterday and i notice the brake light randomly pop on for about 30 seconds then go off. i think hmm werid but it went away oh well. later on it keeps doing it throughout the day, but it always goes off after around 30 seconds. do you think theres something wrong with my brakes or is it just a sensor and how could i fix it if it is just a sensor and if not what do you think it would be, my brakes are soild and i dont FEEL any problems but then again that doesnt really mean ****
Old Jan 13, 2007 | 08:40 AM
fireant's Avatar
Default Re: brake light!! (donnybrook)
There are some common and easy-to-fix issues with the brake light switch on the pedal. That's the first thing you should look at. Search for "Brake light" and you'll see plenty of threads about people's brake lights sticking on and draining the battery that will show you what to look for.
Old Jan 13, 2007 | 09:55 AM
h224thgensedan's Avatar
check your brake fluid. There is a little sensor in the top of the cap.
Old Jan 13, 2007 | 10:36 AM
Targa250R's Avatar
be professional
Check the level of fluid in the master cylinder reservoir. Low fluid will cause the brake idiot light to illuminate. Low fluid level could be caused by worn pads and/or rotors combined with an insufficient fluid reserve (just add a little fluid, and/or plan for a brake job), or could also be caused by a leak in the system (serious! dangerous!).
If the fluid level is good, check the switch on the e-brake handle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">There are some common and easy-to-fix issues with the brake light switch on the pedal. That's the first thing you should look at. Search for "Brake light" and you'll see plenty of threads about people's brake lights sticking on and draining the battery that will show you what to look for.</TD></TR></TABLE>
I think he's talking about the idiot light in the cluster.
Old Jan 13, 2007 | 11:46 AM
donnybrook's Avatar
COULD THIS HAVE ANY REASON TO KILL MY ENGINE? MY CAR HAS STOPPED RUNNING I POSTED ANOTHER THREAD ABOUT IT HERE https://honda-tech.com/zerothread/1862983 PLEASE CHECK IT OUT
Old Jan 13, 2007 | 11:57 AM
Targa250R's Avatar
be professional
Default Re: (donnybrook)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donnybrook &raquo;</TD></TR><TR><TD CLASS="quote">COULD THIS HAVE ANY REASON TO KILL MY ENGINE?</TD></TR></TABLE>
Not unless a short circuit or bad ground is causing electrical issues.
el_huevoEK2099
Suspension & Brakes
Apr 4, 2009 05:55 AM
bandit080000
Feb 1, 2009 05:45 AM
Pullig
Aug 30, 2005 11:51 AM
HardSaltydogg
11
Jun 18, 2005 04:11 PM
Idontknowanything
Oct 11, 2004 03:52 PM
