Simple question: How do you turn off the "maint' required" light??????
Old Jan 13, 2007 | 07:52 AM
Civiclized's Avatar
Default Simple question: How do you turn off the "maint' required" light??????
This may be a dumb question, but I just got the car....
so its its yellow,flashed when you first started the car then wnet off.Now it stays on.From a 97' Civic I had if I remember right, its just a basic reminder light for regular service.But I don't know how the heck to turn it off.
Aprecciate the feed back guys!
Old Jan 13, 2007 | 08:11 AM
Ross 2.0's Avatar
In a Junkyard near you.
pretty sure i already told you this...
Push and hold the trip/ reset button and then turn the ignition on, hold the button till the light goes off
Old Jan 13, 2007 | 08:22 AM
Civiclized's Avatar
Default Re: Simple question: How do you turn off the "maint' required" light?????? (Civiclized)
Alright- about five second after posting this I found the answer:
For 98-01 accords:
1. For the first 6000 miles after completion of scheduled maintenance and indicator light reset, the MAINTENANCE REQUIRED reminder light will illuminate when ignition is turned on, and then will go out after 2-10 seconds.Between 6000 and 7500 miles, the MAINTENANCE REQUIRED reminder light will flash for 10 seconds, and then will go out.After exceeding 7500 miles without having scheduled maintenance performed,light will remain on until it is reset.
2. When service has been completed, reset M.R. light. To reset light, turn ignition off.Press and hold SELECT/RESET button.On Accord,button is located on right side of instrument cluster.
3. While still holding buttons, turn ignition on with engine off.Hold button for 10 seconds until indicator resets.
Hope this helps someone out!
Old Jul 30, 2009 | 05:21 PM
mandybliss's Avatar
New User
This wasn't what I was on here for but it helped. My light was on but I was worried about it because I knew the car had it's maintenance done, just not by a shop. So like I said, not what I was here for, but it helped. TY
Old Jan 4, 2013 | 11:52 AM
107proof's Avatar
Here is a video on how to reset your light. It works on most Honda's up to 2006.
Old Jan 4, 2013 | 11:53 AM
TheMuffinMan's Avatar
He knows where you live!
Why did you bump a 7 year old thread that already has the answer in it with a YouTube video as your first post?
Old Jan 7, 2013 | 12:22 PM
107proof's Avatar
The last post was in July of 09, so it has only been 3.5 years since this was active.
Anyway, I had this problem last week and needed my Maint Required light reset. That's when I came across this site. I always find videos where someone shows how to do it more helpful than than written instructions. So I posted it here.
I figured it would help others that search for the answer in the future. This applies to Honda's up to 2005 and there are plenty of them still out there. I have a 2001 accord and a 2003 accord and it worked for both of mine.
Since I own 2 Honda's, I joined the site. This seems like a good place to get help and help others. I didn't realize it was also a place to question the help offered by others. I apologize if my response was not helpful to you. But it may help someone else.
Thanks
rasta420
Nov 1, 2006 04:06 PM
Thanks knightsport!
Apr 9, 2006 02:53 PM
5Zillahs05EP3
Aug 12, 2005 02:27 PM
biggusf
Mar 29, 2004 08:58 PM
CrAzyGsR101
Acura TL, RL & ZDX
Oct 17, 2003 06:09 PM
