Need help on resetting srs light
As the title says my girlfriend was driving and the srs light came on. I searched it but they say to pull the srs fuse and it didnt work. So I hope someone can help because I do not want to spend 98.00 at the dealer just to reset it for me. Thanks for any help. Its a 2001 civic lx
SRS (Supplemental Restraint System) Light: If your SRS light comes on for any reason, then there is a problem with the SRS system. And when that light comes on, the SRS system will be disabled untill the problem is fixed and light is off. Now you cant go to autozone for them to check this code, it has to be checked by a dealer or any auto shop. The regular OBD 2 scanners cant check for SRS codes unless otherwise specified.
Now pulling the battery cable wont reset the light either.
Now if you happened to remove your front seats for any reason and didnt disconnect the battery before you pulled the connecters to the SRS module and now your SRS light is on, here is the link to the DIY to reset the light, that is if there are actually no problems with the SRS system:
A tire hit her from bumper and caused it to come on no damage to the srs system. I checked it to be sure of that. Just need to reset it. If it were damaged it will come back on after I reset it. If I can ever find out how.
shortdahri
Oct 24, 2006 09:02 PM
