Need some wiring diagrams for clusters
I am in the process of swapping my dash out in my 92 Civic hatch for an Intgera one. I have everything mounted in already but I need some wiring diagrams. I am using an OBD-I interior harness from a 94 Teg, the cluster I am using is a 98 spec USDM ITR. I so far have only got the lighting, e-brake, seatbelt lights and the fuel gauge to work. I have searched for the past 3 hours and can't find a complete diagram of either of the clusters, most are of only 2 connectors, I need all 3.
Thanks
Thanks
You only need two connectors. The middle plug on the Integra cluster is there to plug in if the car was auto for the gear indicator lights. Use the first link in my signature.
Well I am def glad you responded, it was your diagram I had used. The only problem is after switching around the pins I end up with my ABS wire has no where to go. On your 98-01 diagrams I don't see a place where the wire goes but I have to remove it for the seatbelt light wire. Also I can't get my tach or speedo to work, although that maybe just a problem with the VSS. The temp gauge is also not working. Any suggestions?
The ABS wire is integrated in the SRS plug for 98-01 Integras. It will be the blue wire on the yellow SRS plug.
Are you sure you are connecting the yellow wire to the harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 »</TD></TR><TR><TD CLASS="quote">Yeah, I didn't change any of the wiring on the D connector since with your diagrams it seemed everything was already in place.</TD></TR></TABLE>
When I swapped an Integra cluster my friend's EK, D4 was pinned and none of the gauges worked. So I assume, you are not getting power to your cluster. Check your fuses.
Sorry, I cant remember my other paswsword this is my old name. Do you happen to know which fuse the power wire goes to. On your updated diagrams (very nice btw) it says fuse 15 and I'm not quite sure which that one is. I tried pulling some fuses to look if any were blown but its so cold out I only tried about 5-6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigAnold »</TD></TR><TR><TD CLASS="quote">Sorry, I cant remember my other paswsword this is my old name. Do you happen to know which fuse the power wire goes to. On your updated diagrams (very nice btw) it says fuse 15 and I'm not quite sure which that one is. I tried pulling some fuses to look if any were blown but its so cold out I only tried about 5-6.</TD></TR></TABLE>
It's labeled on the fuse box
Power Rev Racing
13
Sep 21, 2005 09:28 PM
*Boostwerks*
30
Mar 6, 2004 09:25 AM
