ABS high pressure system
I have an accord 95 with the alb3 abs system and the warning light often (but not always) stays on after starting (usually ok in the morning). The fault code is 18 - high pressure. Can anyone suggest what might be at fault here or how to fix this problem. I am not aware of any fluid leaks but ill need to take a closer look.
Thanks
Thanks
