is this possibole
some friend say he have :
own a 1999 Honda Civic Original S.i.R with a B16A3 engine . it has all the bits and pieces u might think of . Eagle stroker kit with 12.5:1 compression ration , ported and polished head , titanium valves , crower valve sprngs and retainers , Type R highlift cams , Skunk 2 intake manifold , DC sports exhaust manifold and exhaust system , K and N air filter . AEM fuel rail , RC injectors (310 CCs) , AEM fuel pressure regulator , Skunk 2 68mm throttle body and the Engin stroke has reached 2 liter using 84MM pistons instead of the original 81MM and shorter custom made conn rods
my question is : he say he has 310 cc injectors. and have AEM fuel pressure regulator . so what will controle his new ninjectors ?
am i right ?
am i right ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hany »</TD></TR><TR><TD CLASS="quote">that mean all this setup is correct with stock ecu ?
and if correct what will be the hp at the wheels for this setup ?</TD></TR></TABLE>
theres no way to say how much hp to the wheels that setup has... Every engine build is completely different.
well looking at that list i would assume he has a chipped ecu, or a stand alone (maybe piggy back??) running all that on a stock, unmodified ECU seems a bit of a stretch.
as for horsepower, no real way to tell. 2 of the same exact engine rarely have the same horsepower in stock trim, never mind a hooked up and tuned engine. alot would depend on how tuned it is, fuel, exc.
and as for if he is talking crap or has the car, i would say see it before you believe it. anybody can go online, find some part names and say they have a car with said parts, but magically its always "at the shop" or some other excuse.
Ok, I was under the impression that the B16a3 was only in the 94-95 Honda civic del-sol. So if this person has a 1999 civic of any trim with a B series, it should be a B16a2, B16a, 0r B16b, correct? Alot of this seems far-fetched to me. I believe none of what I hear and half of what I see. So prove me wrong please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedJDM00si »</TD></TR><TR><TD CLASS="quote">Ok, I was under the impression that the B16a3 was only in the 94-95 Honda civic del-sol. So if this person has a 1999 civic of any trim with a B series, it should be a B16a2, B16a, 0r B16b, correct? </TD></TR></TABLE>
it does sound far fetch to me as well.
and the only b16a3 was found in the 94-95 del sol's. there is only one 99-00 civic which cam with a b16 and iwas an si which had a b16a2.
there was never a factory usdm b16a or b16b.
AW
Jun 13, 2003 09:39 PM
