clutch problem??
Old Jan 12, 2007 | 08:11 PM
I_dont_want_a_user_name's Avatar
Default clutch problem??
A friend of mine was givin a honda 93 honda accord ex. He was told the clutch was bad. I went to put a clutch in it today but im not sure if the clutch is the problem.....Ok you can have the car running and with out using the clutch you can go through all 5 gears and the car doenst move. The pedal feel fine. If you put it in 1st and let the clutch out and it does nothing the engine doesnt even bog.
Does this sound like a bad clutch or something else Yea i know its a accord in the civic fourm i posted in the accord fourm and well the really really slow on that side of HT any help??
Old Jan 12, 2007 | 08:25 PM
bmoua's Avatar
might be the axles too...not too sure though correct me if i'm wront anybody...
Old Jan 12, 2007 | 08:31 PM
Default Re: (bmoua)
I though that to but there fine. What weired about it is every car wih a bad clutch will still try to move or something this one litarelly does nothing you put it in frist let the clutch out it just sits there and idles smooth as can be
Old Jan 12, 2007 | 08:58 PM
gezzuzz's Avatar
Default Re: (I_dont_want_a_user_name)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">might be the axles too...not too sure though correct me if i'm wront anybody...</TD></TR></TABLE>
that is the axle.. they are not cliped in.. did yall just installed a new clutch? if so yall didnt put the cv joints in right.. or is someone telling you that you have a clutch problem.. either way sound like the cv joint poped out or broke.. take one cv joint out a few mms and the car will feel like its in netural..
Old Jan 12, 2007 | 09:16 PM
Default Re: (gezzuzz)
I havent touched the car yet but i did look at the axels they where in the tranny I just find it weird that you can have the car running and go through all the gears with out the clutch and it dosent do **** to the car it just idels
Old Jan 13, 2007 | 09:23 PM
gezzuzz's Avatar
don;t mess with the axles while car is running expectally when in gear.. if they are poped out and you touch them and it catch a spline can spin..
Old Jan 13, 2007 | 09:37 PM
Tjames8864's Avatar
yea but if u do decide to have a friend take pics of you gettin hit by the car...and post em up
Old Jan 13, 2007 | 09:50 PM
Zeusfire69's Avatar
Default Re: (Tjames8864)
I sell ALOT of clutches, and I have seen may cars that won't even move when the clutch has been totally destroyed. Usually, it's just worn out enouph for it to just slip some, but if you keep on going and totally incinerate the thing,or if you explode the disc by dropping the clutch to many times, it won't even have enouph grab to move the car. By all means, check to make sure the axles are all the way in first, but it sounds like the clutch is toasted...
xkrntamax
Nov 4, 2008 06:49 PM
Jan 13, 2007 06:15 AM
hondaracin24
Aug 5, 2004 02:26 AM
joecarguy
May 10, 2004 05:49 PM
do0dfromcali
Feb 16, 2004 10:50 PM
