just installed new speakers from shop, but...
Old May 15, 2002 | 01:34 AM
94tegAddict's Avatar
Default just installed new speakers from shop, but...
i got infinity kappa component front and infinity kappa rear speakers installed in my integra from the shop, hooked up to the ADS 6 channel amp and Eclipse 8051 hu. when i tested it out, listening in the car, the sound was loud as hell, but it was strange the right speakers seems louder than the left unless i have hearing problem which i highly doubt. how can i check and see if both side speakers are sound equal. isn't there any device which can measure, or should i take it back to the shop?
Old May 15, 2002 | 05:12 AM
rcurley55's Avatar
New User
Default Re: just installed new speakers from shop, but... (94tegAddict)
Well, first, check the balance on the headunit. If everything checks out there, then sit on the other side of the car...does the left side get louder? If so, it may just be a function of the vehicle.
Also, depending how it was setup, the gains may be off on the amp.
To check it out further...listen to it with it faded up front, and see what you get. The rears my be pulling everything to one side. Also check all crossover connections on the tweeters to see that they are set identical for a right to left bias. While you are there, you may want to pop your drivers in the front stage in an out of phase one at a time to see if you get some better sound. Its rare that any car sounds best with all drivers wired up as written in the instruction manual.
[Modified by rcurley55, 2:15 PM 5/15/2002]
Old May 15, 2002 | 09:38 PM
Default Re: just installed new speakers from shop, but... (rcurley55)
i had two other friends sitting in my car, driver and passenger side, listening to the sound, and yes, we found out right speakers are definitely louder than the other. the balance was set to 0. i don't really know how the wires go, so i'm just willing to take it back to the shop, but is it possible that the amp is unbalanced? I bought used 6 channel ADS, so i'm not sure i can trust it.. i will eventually take the car back to the shop, but just want to get an idea, so i will know what i'm talking about.. thanks..
Old May 15, 2002 | 10:32 PM
rcurley55's Avatar
New User
It depends on how they hooked it up.
a/d/s/ makes an outsanding product. I am using a P650 and a PQ40 in my brother's system, and they are great amps.
Take it back to where you bought it, and have them look at it. The crossover and signal redirection capabilities of that amp can make your head spin, so I wouldn't dive into it unless you know what you are doing.
I still get that amp (p650) wrong, and I've tuned it 3-4 times.
Old May 15, 2002 | 11:19 PM
mine says ph15... are you familiar with it? i will have them look this monday or tuesday..
Old May 15, 2002 | 11:45 PM
rcurley55's Avatar
New User
Sorry, but I don't have any experience, nor have I heard of the ph15. Must be an older model...is it all black with tall aluminum heat sinks that run the full length of the amp? If so, that would be indicative of thier older models...still great amps.
JDMB20TDA
Audio / Security / Video
Oct 7, 2009 04:26 PM
jlc-bigj
May 25, 2004 05:52 AM
IloveNewt
10
Mar 21, 2003 10:23 AM
94tegAddict
Sep 22, 2002 11:07 AM
Rob :190:
Dec 30, 2001 08:38 PM
