Lowered Accord bottoms out, fix?
Old Jan 12, 2007 | 07:27 PM
LSR 0NE's Avatar
Default LOWERED ACCORD
I just dropped my 97 accord, it rides ok but it bottoms out.I lower it with sprit springs(2.50 f 2.25 r)what can I do to fix this problem? Oh yeah i used stock shocks too.
Old Jan 12, 2007 | 07:37 PM
SlowCG's Avatar
Default Re: LOWERED ACCORD (LSR 0NE)
um... not have it so low? what do u mean what can u do to fix it? There isnt anything you can do but raise it up more so u dont bottem out.
Old Jan 12, 2007 | 07:43 PM
TouringAccord's Avatar
H-T Order of Merit
did you cut the bump stops?
Old Jan 12, 2007 | 07:57 PM
mtnwkr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSR 0NE &raquo;</TD></TR><TR><TD CLASS="quote">I just dropped my 97 accord, it rides ok but it bottoms out.I lower it with sprit springs(2.50 f 2.25 r)what can I do to fix this problem? Oh yeah i used stock shocks too.</TD></TR></TABLE>
You answered your own question.
Old Jan 12, 2007 | 08:01 PM
I_dont_want_a_user_name's Avatar
Default Re: LOWERED ACCORD (TouringAccord)
either he cut them or didnt put them back in (my guess) I have made the mistake of not using the bump stops and withen 2 weeks my sturts where blown. And i had a set of sprint springs on my civic hatch for like two years They where nice riding springs but they set the car way to low and i had theproblem of bottoming out......If you didnt put the bump stops back in you might wanna tear it all back apart and do so. itll help with the bottoming out and help you sturts last longer
Old Jan 12, 2007 | 08:04 PM
EvenStar's Avatar
Default Re: LOWERED ACCORD (I_dont_want_a_user_name)
isnt it bad to use stock shocks?
Old Jan 12, 2007 | 08:06 PM
LSR 0NE's Avatar
forgot to put them on! f***
Old Jan 12, 2007 | 08:19 PM
accordselux's Avatar
Me Gusta History
Default Re: LOWERED ACCORD (EvenStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvenStar &raquo;</TD></TR><TR><TD CLASS="quote">isnt it bad to use stock shocks?</TD></TR></TABLE>
Horribly bad.
A few months from now he's going to be a living bobblehead.
I'd put some decent aftermarket shocks on ASAP. I had my car lowered 1.25" and they were blown in less than a year.
Old Jan 12, 2007 | 09:20 PM
pos_cd5's Avatar
Default Re: LOWERED ACCORD (accordselux)
get aftermakret shocks and use the bumpstops if you arent already. and be sure to cut them down to spec.
Old Jan 12, 2007 | 09:58 PM
FRISBEE's Avatar
Default Re: LOWERED ACCORD (pos_cd5)
First of all I hope you don't have a 6 cyl w/ 4 cyl springs! If you do have the 4 cyl the thing I used to do at our shop with such a large drop was to cut away the very top of the front inner fender well(under the hood) next to the strut mounting location, You'll see a little rubber button (about 1/4 large) This will be your pilot hole to cut the top off with a 3" hole saw or a sawzall (do not cut more/past than the seam sealer) this will allow the control arm to have a little more travel, If you don't do this your uppper ball joint will seperate from your control arm, and Honda does not sell this part seperate. Also if you try to use a camber kit you'll run into more problems like your control arm smashing on the inner fender well seam. My advise to guys like you was to raise the car and have a better ride and less headaches, If you want it that slammed go to air struts.
Old Jan 13, 2007 | 06:05 AM
H-T Order of Merit
yeah, I would atleast put the bump stop back in and cut them to the specs the springs call for. But your best bet is to buy aftermarket struts that are meant to handle lowered cars.
Old Jan 13, 2007 | 06:16 AM
LSR 0NE's Avatar
thanks for your help. What kind of shock sould i go with? & how much do I have to cut the bump stop?
Old Jan 13, 2007 | 06:41 AM
H-T Order of Merit
I'm not sure how much you need to cut the bump stop, the spring install instructions should supply you with that info.
You want something that can handle your drop. On my Accord and my Civic I had/have Tokico blues. But neither of them had a huge drop. I don't remember what my Civic is but my Accord was only 1.25" drop. On my next Accord I plan to get something adjustable, maybe Koni, not sure yet.
Old Jan 13, 2007 | 06:48 AM
LSR 0NE's Avatar
Again,thanks next time I will go with some thing less drastic.
Old Jan 13, 2007 | 06:54 AM
H-T Order of Merit
yep, no problem
Old Jan 13, 2007 | 12:16 PM
pos_cd5's Avatar
koni yellows or KYB AGX should work well for you
Hyard24
Suspension & Brakes
Jul 5, 2008 10:52 PM
Boonie Buster
Aug 5, 2005 08:46 PM
0554
13
Feb 24, 2004 09:44 AM
