fit?h23 oil pan fit on a h22a4??
Old Jan 12, 2007 | 06:24 PM
DrivinVtec's Avatar
Default fit?h23 oil pan fit on a h22a4??
just like the title says. will it fit
Old Jan 12, 2007 | 06:38 PM
alterdcreations's Avatar
Default Re: fit?h23 oil pan fit on a h22a4?? (DrivinVtec)
i do not think so
Old Jan 12, 2007 | 06:44 PM
DrivinVtec's Avatar
im not a 100% either
Old Jan 12, 2007 | 07:07 PM
v4lu3s's Avatar
RTFM
yes it will fit, it does not have the benefits of the cast aluminum an adding rigidity, but it should bolt up. the h22, h23 and f22 all share the same oil pan outline.
Old Jan 12, 2007 | 07:12 PM
DrivinVtec's Avatar
so your saying it not as strong???
Old Jan 12, 2007 | 07:26 PM
Default Re: (DrivinVtec)
my machine shop tried to bolt up a f22 pan to my h and its different
Old Jan 12, 2007 | 07:39 PM
DrivinVtec's Avatar
DOH!!!!!! I kinda need to kow this. Ill be haven the turbo drain line welded. dont want to waste money on something i cant use.
Old Jan 12, 2007 | 07:49 PM
PrecisionH23a's Avatar
The pan fits and works. You will have to use a 4th gen oil pan gasket. The 4th gen oil pan also does not have the holes for the flywheel cover. I believe you can still use the cover though and use 2 bolts going to the tranny and block.
Old Jan 12, 2007 | 07:51 PM
DrivinVtec's Avatar
can i use some og that sealent for a gasket? the grey stuff?
Old Jan 12, 2007 | 07:57 PM
Probably not... the 4th gen pan has bumps. So if you used HondaBond you would have to cake the **** on beyond belief.
Old Jan 12, 2007 | 08:02 PM
DrivinVtec's Avatar
Default Re: (PrecisionH23a)
okay. thanks for the help
Old Jan 12, 2007 | 10:58 PM
92blkJDMh22's Avatar
yes, i had an SH oil pan on my old H23... worked just fine....
Old Jan 12, 2007 | 11:05 PM
DrivinVtec's Avatar
Default Re: (92blkJDMh22)
good deal. i guess ill get to work on this apn tomorrow then
Old Jan 13, 2007 | 08:37 AM
Default Re: (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">my machine shop tried to bolt up a f22 pan to my h and its different</TD></TR></TABLE>
stupid machine shop
Old Jan 13, 2007 | 09:44 AM
jdmcivicferio's Avatar
to use a alluminum oil pan on a a pre 1997 motor you need to use the windage tray as well from a 97+ or it won't fit
Old Jan 13, 2007 | 12:08 PM
DrivinVtec's Avatar
Default Re: fit?h23 oil pan fit on a h22a4?? (jdmcivicferio)
so if i use the h23 oil pan on the h22a4(01) i should be fine then?
Old Jan 13, 2007 | 04:12 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec &raquo;</TD></TR><TR><TD CLASS="quote">so if i use the h23 oil pan on the h22a4(01) i should be fine then?</TD></TR></TABLE>
Old Jan 23, 2007 | 11:20 AM
JDMugenBB1's Avatar
Default Re: fit?h23 oil pan fit on a h22a4?? (md23vtec)
On majestichondaparts... it indicates the oil-pan part # (93755) is the same for all ludes (S, Si, VTEC) from '92-'93.
And the oil-pan part # (109843) for all lude models from '94-'96 are the same.
Can anyone confirm this??
Ceasar
SteelcityLude
Feb 12, 2012 05:40 PM
pacmann_9595
Aug 19, 2007 04:19 PM
ozzyman
Apr 30, 2005 01:41 PM
spoolinlude
May 27, 2003 06:24 PM
fastludeh22
Dec 6, 2002 10:36 AM
