B18C5 or K24 setup.....CHECK THIS OUT
For those that dont know ive got a b18c5. plans for it are as follows:
Skunk2 pro 1 cams/gears, valvetrain, all necessary head work
Victor X manifold, plus size tb
Header (undecided at this point), RS*R exhaust, short ram air induction
Hondata
Here lately ive been intrigued by the k24 long blocks. Obviously there is more power to be gained with a k24. so am i just getting a bad case of the wants? or should i sell the itr and do the k series?
and i know the difference in the motors and potential that each one has, so theres no need to hate
Hondata
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote">first of all, is this gonna be for daily driven or strictly track?
if daily driven then b18c5, if track only K24 is the way to go...
itll be a daily....but the k24 should be just as streetable as the itr....call me out if im wrong
</TD></TR></TABLE>itll be a daily....but the k24 should be just as streetable as the itr....call me out if im wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardt »</TD></TR><TR><TD CLASS="quote">Comparing a B to a K, no question, go with the K.</TD></TR></TABLE>
thats what i was afraid everyone was going to say.......if i didnt have the b series already i would definitely go k. if someone can persuade me enough to buy the k series i might just sell the b
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitrna »</TD></TR><TR><TD CLASS="quote">thats what i was afraid everyone was going to say.......if i didnt have the b series already i would definitely go k. if someone can persuade me enough to buy the k series i might just sell the b</TD></TR></TABLE>
Displacement
Variable cam timing
Having the exhaust on the correct side of the engine, instead of directly behind the radiator
Choice of 5 or 6 speed tranny
Displacement
Variable cam timing
how about me give you 3gs for your c5 motor and you can use that to help you buy a k series..
if you got the money k20a tuned will be badass...but i dont really mind any other k series either...just incase you want to sell your c5 and you are also located in cali LMK how much you want..
The B18C5 platform is FAR superior to a K24 motor. The K24 has a weak bottom and characteristicly, it's not ideal for drag racing. However, the 24 block would be a good candidate for autocross due to it's torque curve. If you were going to build a K for track use, i'd stick with the K20 block.
Kseries are a PITA to tune as well compared to Bseries.
You could easily squeeze out 225/150 out of that setup with some good cams, headwork, and a good header. I don't recommend using the Victor-x manifold unless you plan on revving to 10k as it will kill your midrange. There's nothing wrong with the ITR manifold/TB.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">There's nothing wrong with the ITR manifold/TB.</TD></TR></TABLE>
yeap just bore it out if ur goin crazy
back on topic stick with type r build..but i would go with better cams/valvetrain then skunk2.. u can make alot of power with those type r even with a stock block w/ built head of course.. rocket motorsport got good stuff..if ur interested talk to "clean rice" he kno his stuff
my choice for headers is either 4-1(rmf) or 4-2-1 (smsp) good luck on the decision
Honestly, i'd recommend some good headwork, a nice Tri-Y header, and some BC4's or M22x's. Stock block, it could probably pull 215-225 whp with tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team1320_k24eg6 »</TD></TR><TR><TD CLASS="quote">go with the k24 block / k20 head... you wont be disappointed...
I would be, with the torque curve that is (not the actual number produced).
</TD></TR></TABLE>I would be, with the torque curve that is (not the actual number produced).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">I would be, with the torque curve that is (not the actual number produced).</TD></TR></TABLE>
wtf??? you serious?
wtf??? you serious?
are you talking stock k24/k20a2 setup or fully built up vs your currently built b18c5 ?
if you are talking stock then keep your current setup, or then you're just blowing away money for a setup that will prolly be equally as fast ... I'm sure your current setup is a good 220-230hp setup, typically arund the same as a stock k24/k20a2 with header/ecu/cams and tuning.
If you plan on eventually spending lots more $$ to build up the k motor then start saving now and sell your setup later on.
?unfortunately the b-series value has depreciated so much its just a fine line to balance between takign a loss on the built b series vs. starting new with the K.
I'm an advocate of the K dont get me wrong, but it doesn;t sound liek you should get rid of what you have to jump a bandwagon when your current setup can keep up with the "stock" K hybrids out there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">I'm an advocate of the K dont get me wrong, but it doesn;t sound liek you should get rid of what you have to jump a bandwagon when your current setup can keep up with the "stock" K hybrids out there.</TD></TR></TABLE>
FYI.....im not jumping onto the bandwagon. my car would have already been built with the standard stuff if i was all about the bandwagon. yet, i've been searching and searching for mods for about 7 months now to try and make my build as unique as possible. ive had my eye on k series motors far before they became mainstream........dont get me wrong i would hate to get rid of my c5, but its not mainstream when you see the potential of a k series is substantially more significant than that of a b.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLue eGG »</TD></TR><TR><TD CLASS="quote"> my choice for headers is either 4-1(rmf) or 4-2-1 (smsp) good luck on the decision </TD></TR></TABLE>
randy makes a new narrow style b-series header that ive been inquiring about for sometime now. yet with the new cams, etc setup that i want to do im not so sure that ill have the money for a header that expensive. my thoughts here lately though is that i might put off the carbon fiber hood, tailgate, and interior mods in order to do motor motor motor
thats all that matters to me anyway
I would be, with the torque curve that is (not the actual number produced).</TD></TR></TABLE> Wouldn't the 2.4/type S head with that big stroke have a wonderful torque curve, far better than a modified c5.....maybe I misunderstood you?
Also, what part of the bottom end specifically is weak on these K24s--I am not so sure that is true, although I personally don't have any experience with them.
the k24/k20 set up makes more torque than the c5 makes hp..... so i dunno wtf your talking about.... you obviously don't own a K series.... hell i take take the k20a type r over the c5.... k20a runs hard... i see them run mid 12's in a eg all day long with minor mods... a b18c5 would never do that with bolt ons....
Modified by team1320_k24eg6 at 6:26 PM 1/13/2007
Modified by team1320_k24eg6 at 6:28 PM 1/13/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote"> Wouldn't the 2.4/type S head with that big stroke have a wonderful torque curve, far better than a modified c5.....maybe I misunderstood you?
Also, what part of the bottom end specifically is weak on these K24s--I am not so sure that is true, although I personally don't have any experience with them.</TD></TR></TABLE>
1. I'd personally rather have a torque curve that peaks at 8 or 8.5k (for drag racing) with the 87.2mm crank than an 99mm one that peaks at 5 or 5.5k and starts falling off as all of your k24/k20 builds do. The K24 produces some pretty high piston speeds and a low R/S which is part of the reason it peaks early and starts running out of steam. Although when it does peak, it's capable of 200+ wtq in fully built status. You could possibly alleviate part of this problem by swapping cranks and destroking to a 2.3 or going with a custom rod/piston/wristpin. Go ahead and search, most K20/24 builds utilizing the 2.4 crank aren't really making impressive numbers with whp in the 180/190 whp range and wtq in the 150 ftlbs range. Add some headwork and cams, and you could make it to 215-225whp fif you're lucky. I'm not impressed. The OP could extract that out of the ITR with cams, headwork and a header, all while not worrying about taking it to 9k on stock rods. I'd much rather run a 250-260 whp/ 160-170 wtq Bmotor with all off the shelf parts. Both setups are capable of going 10's in the right chassis, but the K is more expensive and more difficult to tune. Don't forget the body modifications and suspension to accomodate one.
2. OEM K24 rods/rod bolts.
What threads have you been looking at? Most K24 franks are in the 220-230 range. I could link you to multiple threads on here and k20a.org, from reputable shops and people.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer »</TD></TR><TR><TD CLASS="quote">What threads have you been looking at? Most K24 franks are in the 220-230 range. I could link you to multiple threads on here and k20a.org, from reputable shops and people.</TD></TR></TABLE>
Stock block? Link me.
Stock block? Link me.</TD></TR></TABLE>
http://www.k20a.org/forum/showthread.php?t=22642
