How to install rear valence?
Old Jan 12, 2007 | 01:37 PM
ITR0529's Avatar
Default How to??????
Just curious as to how you mount the rear valences on the teg? What all is required? any modding or is it a direct fit? I've seen the bumper after they are off and it looks like drilling is required to mount. the reason I ask is because I really don't know what is required? All input is appreciated.
Old Jan 12, 2007 | 03:13 PM
christuffeR's Avatar
Default Re: How to?????? (ITR0529)
When i first had rear valances i used screws to hold them on the bumper. There are brackets on the oem pieces that you can use to put screws in and hold it on the bumper. Unfortunately it was stolen off my car. But the oem pieces do fit right on the bumper, so its a nice fit.
I have bought another set of valances and have had them molded on to my bumper. Someone cant just unscrew them off now. but i'm sure if they want it bad enough they'll find a way to take it.
Old Jan 12, 2007 | 05:44 PM
Hooch'n's Avatar
Default Re: How to?????? (christuffeR)
superglue
Old Jan 12, 2007 | 08:57 PM
mugenitrturbo's Avatar
Default Re: How to?????? (Hooch'n)
duck tape works on anything.........lol
Old Jan 13, 2007 | 05:02 AM
MiraiZ's Avatar
Default Re: How to?????? (mugenitrturbo)
The screws should be all you need
Old Jan 13, 2007 | 07:29 AM
DooD's Avatar
when i installed mine, it required 1 screw in the back and 2 in the fender. The hardest part is knowing where to drill a hole in the rear dumper to put the screw through.
Old Jan 13, 2007 | 12:10 PM
Doostur's Avatar
When I get home I will scan in the instructions for you from my set i just put on. Will include what tool are needed for install to what parts/screws and better yet the partnumbers to order from acura
Old Jan 13, 2007 | 12:20 PM
Doostur's Avatar
By the way i cant remember exactly but there is one hole they have you make that never lines up and you really dont need. Id have to look at the instructions to know.
Old Jan 13, 2007 | 12:29 PM
Doostur's Avatar
Default Re: (Doostur)
Old Jan 13, 2007 | 03:58 PM
BLacK FirE's Avatar
http://www.pbase.com/jw_system...tions
Old Jan 15, 2007 | 04:25 AM
MiraiZ's Avatar
Default Re: (BLacK FirE)
I used a water based marker and wet the mounting points on the rear valence. I then lined it up with the bumper and press hard until the ink made and impression on the bumper. I was enough to give me an idea where to drill the holes.
Another way is to double sided tape and kind of weaken the ahesive with water on one side. Press the weak side ontot he mounting points on the valence and press it hard against the bumper. The remove it carefully so that the tape is left on the bumper. Use the tape as a reference point to drill the holes.
Old Jan 15, 2007 | 06:54 AM
Mr.OB*GYN_Rhett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE &raquo;</TD></TR><TR><TD CLASS="quote">http://www.pbase.com/jw_system...tions</TD></TR></TABLE>
Old Jan 15, 2007 | 09:54 AM
ITR0529's Avatar
Thanks to everyone for the input. That website was extremely helpful.
Old Jan 15, 2007 | 01:45 PM
NIKE SB'd's Avatar
Beat me to it
omehegan
Oct 27, 2004 02:07 PM
Zulu888
Sep 22, 2002 06:46 AM
acuraLSSE95
Oct 26, 2001 09:10 PM
