Ground Control Coilovers and KYB AGX on CRX with GSR Swap
While searching I found out the spring rate for CRXs is 350f/245r and was wondreing if this will be too soft with my heavier engine. I think the AGXs cannot handle more that 400 without losing the warranty.
Anyone running a similar setup with the default rates or did you choose a higher rate?
tgreaves
Sep 2, 2005 12:37 PM
