gutting engine bay, help
Old Jan 12, 2007 | 12:34 AM
teg_racer's Avatar
Default gutting engine bay, help
im leaving the fuse box and the batterie, the a/c has already been removed and the abs is going too, what else can i get rid of and also i circled a box in yellow, what is it and can it be removed
Old Jan 12, 2007 | 12:39 AM
tomithy's Avatar
you trying to tuck wires and stuff too or just remove?
Old Jan 12, 2007 | 04:23 AM
gsr dood's Avatar
Default Re: (tomithy)
black box is crusie control....take it out if u dont mind not having it
Old Jan 12, 2007 | 08:21 AM
Rikter's Avatar
Got ABS you can remove that. Got power steering? You can get rid of that too.
-Rik
Old Jan 12, 2007 | 12:45 PM
Nataku's Avatar
Default Re: (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">black box is crusie control....take it out if u dont mind not having it</TD></TR></TABLE>
Anything I would need to know about removing the cruise control?
Old Jan 12, 2007 | 12:57 PM
aaronISthrowed's Avatar
Default Re: (Nataku)
CC is simple to take out. Search theres a little write up somewhere.
Old Jan 12, 2007 | 01:10 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: (aaronISthrowed)
cruise control removal is very basic. there is a the black box you unplug the wiring to it. and then unbolt it. you climb under the dash and disconnect the CC cable make sure it's not the throttle one though haha.
Old Jan 12, 2007 | 01:52 PM
E-Money's Avatar
Default Re: gutting engine bay, help (teg_racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg_racer &raquo;</TD></TR><TR><TD CLASS="quote"> abs is going too </TD></TR></TABLE>
your gonna want that ABS to be there when you gotta make a sudden stop, wire tuck/removal bandwagon
Old Jan 12, 2007 | 02:13 PM
Default Re: gutting engine bay, help (E-Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">
your gonna want that ABS to be there when you gotta make a sudden stop, wire tuck/removal bandwagon </TD></TR></TABLE>
The Integra RS doesn't have it, most (or all) of the older civics don't have it.
Old Jan 12, 2007 | 10:40 PM
teg_racer's Avatar
Default Re: gutting engine bay, help (aaronISthrowed)
for removing abs, is there a trick to it or do i just simply take it out and all the wires coming from it,
i would hate to take it out and later find that it controlls all my brake lines
Old Jan 12, 2007 | 10:42 PM
nate_2k5's Avatar
i've heard that once the rotors get heated up it is about impossible to lock them up anyway. is there truth to that?
Old Jan 13, 2007 | 05:52 AM
JoePSI's Avatar
Default Re: gutting engine bay, help (nate_2k5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 &raquo;</TD></TR><TR><TD CLASS="quote">i've heard that once the rotors get heated up it is about impossible to lock them up anyway. is there truth to that?</TD></TR></TABLE>
Your brakes don't work as well when they get hot; hints why race crews spend R&D on brake venting/cooling. Hot brakes will lock up too.
Old Jan 13, 2007 | 06:39 AM
Default Re: gutting engine bay, help (JoePSI)
If your taking out ps pm padawan, he sells kits for that.
Old Jan 13, 2007 | 07:09 AM
Nors's Avatar
Not true at all. Any car with out ABS is you really lay on the brake (both feet) at like 45mph all four wheels should lock up.
Heating your brakes up makes no difference.
Old Jan 13, 2007 | 08:18 AM
teg_racer's Avatar
Default Re: gutting engine bay, help (Nors)
does it just come right out or do i have to do something with it
Old Jan 13, 2007 | 08:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg_racer &raquo;</TD></TR><TR><TD CLASS="quote">does it just come right out or do i have to do something with it </TD></TR></TABLE>
Search, you have to get the brake booster off of an RS and some other stuff.
Old Jan 13, 2007 | 08:46 AM
mstolars's Avatar
You can't just remove the ABS control unit, you have to remove all the lines in the front, prop valve and master cylinder/brake booster. Then, you have to install non-abs parts, the only lines you don't have to remove are the rear lines.
Old Jan 14, 2007 | 04:22 PM
cmwright1986's Avatar
^^^ wow. is there a write-up anywhere to help ppl out w step-by-step instructions?
Old Jan 14, 2007 | 05:46 PM
DamnYank!'s Avatar
you don't know what these parts are, what they do, or whats involved in removing them... yet you want to get rid of features that were put on your car for a reason??
i think you need to learn/read more about your car first (do some investigation instead of just asking others to give you the answers) before you start tearing it up just to have a 'clean engine bay'.
Old Jan 14, 2007 | 05:54 PM
Dogginator's Avatar
Daisy... Daisy...
When I bedded my Hawk HPS pads after my 282mm front brake upgrade, my ABS was still engaging on the 10th consecutive stop from 60MPH-5MPH with Yokohama ES100 tires. There was smoke rolling from beneath the car after the third stop. After the tenth stop, it looked like my car was on fire.
Old Jan 14, 2007 | 05:55 PM
teg_racer's Avatar
Default Re: (DamnYank!)
guess this is getting a little more complicated than it was meant to be, bottom line, things i dont need i want gone, i asked for imput and what things could be removed without having a negative effect. all i want to do is clean up the engine bay. hence the title
Type-Spaz
17
Jan 31, 2010 10:00 AM
C-West Civic
Dec 18, 2007 12:54 PM
Mad Cow
Dec 14, 2006 01:26 PM
a1320addict
Sep 3, 2005 09:57 PM
ShootingStar
May 22, 2002 11:46 PM
