Help...OEM honda piston rings have to much of a gap.
Old Jan 11, 2007 | 10:24 PM
FIGARILA's Avatar
Default Help...OEM honda piston rings have to much of a gap.
I'm Building a b17 block with over sized p73's the machine shop bored out the the cylinders to the pistons. I checked the end gap of the rings in the bore and three of them are +.003 past the service limit one is under the the service limit. Is it possible that i got the wrong size piston rings? any opinions
The reason i posted this here was i intended to build this strictly as an N/A engine but the end gap is more then i would expect on a non turbo motor.
Old Jan 12, 2007 | 04:58 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Help...OEM honda piston rings have to much of a gap. (F I G A R I L A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F I G A R I L A &raquo;</TD></TR><TR><TD CLASS="quote">I'm Building a b17 block with over sized p73's the machine shop bored out the the cylinders to the pistons. I checked the end gap of the rings in the bore and three of them are +.003 past the service limit one is under the the service limit. Is it possible that i got the wrong size piston rings? any opinions
The reason i posted this here was i intended to build this strictly as an N/A engine but the end gap is more then i would expect on a non turbo motor.</TD></TR></TABLE>
The machine shop most likely bored out your cylinders too much.
Old Jan 12, 2007 | 11:14 AM
FIGARILA's Avatar
Default Re: Help...OEM honda piston rings have to much of a gap. (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
The machine shop most likely bored out your cylinders too much. </TD></TR></TABLE>
thats what i was thinking but the clearance is pretty tight on the pistons (when placed with in a cylinder).
Old Jan 12, 2007 | 12:03 PM
Banned
Well, It's not like the pistons are supposed to wiggle around in the cylinder. Measure the bores.
cyanid3
May 30, 2014 10:36 PM
Spoon84
Jul 19, 2010 01:34 PM
MatHadder
Nov 19, 2006 11:04 AM
Sport_Injected
Jul 29, 2004 03:15 AM
bretx0r
May 11, 2003 06:14 AM
