WHY DOSE MY 1990 CIVIC...
Hi i have a 1990 civic its a automatic and it won't go over 3200 rmps out do i fix it? please email me at pmoney0657@hotmail.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaddict14 »</TD></TR><TR><TD CLASS="quote">sounds like the engine is running in safe mode</TD></TR></TABLE>
LMAO!!!
LMAO!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 »</TD></TR><TR><TD CLASS="quote">
LMAO!!!</TD></TR></TABLE>
That wasn't a joke.
Limp (or safe mode) is where the motor runs in a closed circuit, ignoring input from variable sensors. This severely limits the capabilities of the motor, because fuel and spark become, more or less, independent.
That wasn't a joke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
That wasn't a joke.
Limp (or safe mode) is where the motor runs in a closed circuit, ignoring input from variable sensors. This severely limits the capabilities of the motor, because fuel and spark become, more or less, independent.</TD></TR></TABLE>
ef_9 why would you post that when your getting good advice?
That wasn't a joke.
I like that, you make fun of him for helping you and giving you a legit answer while you're posting in the wrong ******* forum. Good job buddy. I'll help you out because I pity you.
92-00 EXCLUDES '90.
Yeah, surprising, isn't it?
So if I exclude the fact that you're in the wrong ******* forum I have to agree w/ boostaddict, though it's not called safe mode, it's called limp mode. The ECU in your car decided that due to a particular problem (usually a major one) that you should keep the RPM as low as possible to prevent further damage.
Though I didn't even know 4th gen civics had limp mode...
Either way, you NEED to find out what that CEL means.
EDIT:
PS: Another possibility is I've seen this with fuel pumps that are ready to go, but if you have a CEL (check engine light) I'd check that out first.
92-00 EXCLUDES '90.
EDIT:
