getting a code 9
Old Jan 11, 2007 | 09:37 PM
zccrx's Avatar
Default getting a code 9
im getting a code 9 on my dohc zc. is that the sensor on the exhaust cam or is it in the distributor. i might have to replace it.
Old Jan 11, 2007 | 09:55 PM
xx89civicracer89xx's Avatar
Default Re: getting a code 9 (zccrx)
yes it is ur cam angle sensor (aka the sensor on ur exhaust cam) u have to run the wires to ur ecu... i forgot wich 2 wires it is on the ecu side but ill check my crx tom and get back to ya
Old Jan 12, 2007 | 07:04 AM
jlicrx's Avatar
code 9 is Cylinder Sensor which is the sensor on the exhaust camshaft - the Cylinder Sensor on the DOHC ZC rarely goes bad - the most likely causes for the code 9 are incorrect camshaft timing or a problem in the wiring
Old Jan 12, 2007 | 10:22 AM
zccrx's Avatar
Default Re: getting a code 9 (jlicrx)
i can check the sensor with an ohm meter right?
Old Jan 12, 2007 | 10:31 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccrx &raquo;</TD></TR><TR><TD CLASS="quote">i can check the sensor with an ohm meter right? </TD></TR></TABLE>
yes, unplug 2-pin connector and check for resistance between the two terminals on the sensor connector - should be 700-1000 ohms - also, with it disconnected, check to see if you have continuity between either of the terminals and ground - if so, sensor is bad
Old Jan 13, 2007 | 11:29 AM
zccrx's Avatar
ok so i put the multimeter to use. when i check continuity on the sensor side i get a consistent 954 reading which i assume is right. when i check the side that goes to the ecu it stays at 1 is this right.
leonardsmith
Honda CR-V & Element
Dec 1, 2021 06:33 PM
EG6-SIRII
Sep 11, 2006 03:22 PM
Xgen
Aug 31, 2004 07:44 AM
Jagan'92
Jun 10, 2004 07:43 AM
mbsi
Apr 8, 2003 07:01 AM
