just wondering if ittle work or not?
Old Jan 11, 2007 | 05:30 PM
pnoipj89's Avatar
Default just wondering if ittle work or not?
i am doing a changeing my head to a gsr head? do i have to get new studs for them to fit on directly, or can i just plug and play? from a b18b to gsr heads
Old Jan 11, 2007 | 05:31 PM
mrdeadman's Avatar
They let me pick
Default Re: just wondering if ittle work or not? (pnoipj89)
Read more. If you want to just plug and play you will be severly disappointed.
Old Jan 11, 2007 | 06:14 PM
pnoipj89's Avatar
Default Re: just wondering if ittle work or not? (mrdeadman)
does that mean i have to doe some more machining to the base for it ti sit on properly? on a ls block non vtec?
Old Jan 11, 2007 | 06:16 PM
mrdeadman's Avatar
They let me pick
That means you can't just through on a vtec head and call it vtec.
There is more to it than just bolting up the head.
Old Jan 11, 2007 | 06:18 PM
mike5809's Avatar
I hope your mechanic skills are better then your grammer skills, or you will be severly dissapointed.
pnoipj89's Avatar
i knw that from my knoledge, but am i correct about maching new placements for the studs on the base for the head to sit on though?
Old Jan 11, 2007 | 07:55 PM
CleanLikeJdm's Avatar
Hype-R Stalker
First, I hope English is your second language with how bad your spelling is ..
And if you have to ask so much as to what "Ls-Vtec" is,
you may want to take your engine/car to someone that Has done it,
Or atleast has a little more knowledge on the matter.
It's not something you wanna just "throw" together, because then you get to ride the bus.
Old Jan 11, 2007 | 08:16 PM
jacobolito's Avatar
Default Re: just wondering if ittle work or not? (CleanLikeJdm)
yes use the search button on the top right hand side and see how much is involved in the process
https://honda-tech.com/zerothread?id=1676914
this is the ls-vtec write you need to read before trying anything
Old Jan 12, 2007 | 07:32 PM
pnoipj89's Avatar
Default Re: just wondering if ittle work or not? (jacobolito)
but my question is if you have to machine new holes for the new head to fit on with the new studs for vtec?
Old Jan 12, 2007 | 07:50 PM
Racermech's Avatar
no, but you do need to run an oil line to the head, and that will require some drilling and taping. Also you will need ot run some wires and do other work.
Basically you cant just slap a GSR head on to an LS block and think it will work. It wont. Even if you did not care about vtec you still need to do work just to have it run.
Old Jan 12, 2007 | 10:23 PM
0260MOTORSPORTS's Avatar
SEARCH "LS-VTEC" golden eagle has a bad *** LS VTEC kit
blurry454
Jun 28, 2009 10:33 PM
Nestah
13
Feb 9, 2009 10:30 AM
Muuurph
17
Sep 26, 2008 01:37 PM
LSVTECoupe
Dec 12, 2003 03:46 PM
stock94
Nov 7, 2003 06:35 PM
