Bigger brakes?
Old May 14, 2002 | 09:37 PM
93SSPHatch's Avatar
Default Bigger brakes?
I currently have a 93 CX with stock brakes. . .i plan on putting a bigger engine in by winter. . .my stock brakes/rotors need to be serviced. . .my local shop says that I should upgrade to BREMBO slotted rotors in front with stainless lines and new pads. . .I've read that I really won't need the bigger brakes for everyday driving. . .any advice
should i go with brake upgrade. . .or should I save the money and just replace and resurface the stock brakes?
Thanks
Old May 14, 2002 | 10:26 PM
TypeSH's Avatar
Default Re: Bigger brakes? (93SSPHatch)
up to you really, i'd say since you do need a brake job might as well upgrade. You might not need all the stuff he mentioned, maybe just integra brake rotors, calipers, pads and the misc stuff(whatever works i guess).
Old May 14, 2002 | 10:42 PM
93SSPHatch's Avatar
Default Re: Bigger brakes? (TypeSH)
If I do decide to replace my stock brakes, what year Integra Brakes/Rotors should I replace them with?
Old May 14, 2002 | 11:16 PM
tonyxcom's Avatar
you should be more then happy with an integra brake upgrade.
you can use from any integ 94 and up.
If the front, you will need to swap the spindles and hub assembly that will have the rotors and calipers
Old May 14, 2002 | 11:27 PM
93SSPHatch's Avatar
Default Re: Bigger brakes? (tonyxcom)
What can I expect to pay for this setup. . .and should I go ahead and replace the integra rotors with slotted ones. . .or should i keep everything stock? Do I need to add steel braided lines?
Old May 15, 2002 | 05:17 AM
Mista Bone's Avatar
D Tranny Guru
keep stock rotors and Teg knuckle swap should only be $150
LOW_ONBILLETS
Honda CR-V & Element
Jun 12, 2011 03:50 PM
kimokalihi
22
Dec 9, 2008 05:29 PM
RedSiHatch
Oct 30, 2006 08:15 PM
ninor
Acura TSX
12
Jan 17, 2005 08:24 AM
greensleeper
Apr 8, 2002 01:19 PM
