Easy Drain on Gas tank?
Old Jan 11, 2007 | 03:20 PM
allnaturalb16's Avatar
Default Easy Drain on Gas tank?
I own an 87 crx and was wondering if there is any easy way to drain some old gas that has beeen sitting in the tank?
is there a plug on the bottom of the tank or is it even exposed on the bottom?
Old Jan 11, 2007 | 06:13 PM
Default Re: Easy Drain on Gas tank? (allnaturalb16)
no one?
not even a way on other chasis?
Old Jan 12, 2007 | 12:44 PM
dognutz's Avatar
I think there is a bolt for 92-95 I don't know if that helps. Another option is remove the fuel pump and syphon(?) some out. then add fresh gas or fuel treatment.
Old Jan 12, 2007 | 12:53 PM
havok hybrid's Avatar
Default Re: Easy Drain on Gas tank? (dognutz)
jack the car up.. look around on tank for a drain plug.. it should be like a 17mm bolt.. in one of the corners..
Old Jan 12, 2007 | 01:09 PM
bart2546's Avatar
Default Re: Easy Drain on Gas tank? (havok hybrid)
Should be a drain plug however use the old stick a garden hose in the tank filler tube to the bottom of the tank, and use the syphon method just don't get any in your mouth, nasty **** right there. Also a nice reference for if gas goes up high again and you have neighbors that leave their cars sitting on the street and don't have gas cap locks
Old Jan 13, 2007 | 01:17 PM
Default Re: Easy Drain on Gas tank? (bart2546)
thanks ill look for the bolt hopefully its there. the gas has been in there for about a year and with my new swap i dont want to use any of that old fuel. its probably just water now!
kornerk12
Mar 18, 2007 09:13 AM
JDM00SI
Oct 26, 2005 09:41 AM
1 Cam Wonder
30
Oct 21, 2004 10:14 PM
96SR-V
Mar 11, 2004 07:52 AM
gOSetonHall
Sep 6, 2002 12:56 PM
