RHINO??? adj. upper control arms 88-91 civics
Old Jan 11, 2007 | 01:01 PM
hybridmoments's Avatar
Default RHINO??? adj. upper control arms 88-91 civics
http://cgi.ebay.com/ebaymotors...QrdZ1
anyone used these?? cheap as hell. tha design looks same as the REVO arms.
wonder if the balljoints are complete crap and that is why they are so cheap?
only other company i've seen with fitment for the 88-91 civic arms is Revo Technica at $100 more
Old Jan 11, 2007 | 01:06 PM
djphonics's Avatar
Default Re: RHINO??? adj. upper control arms 88-91 civics (hybridmoments)
The design does look almost the same as the Revo arms...only they are WAY cheaper. I don't know what's up with that.
Old Jan 11, 2007 | 01:13 PM
maybe they are made out of Gummi Bears? might be worth it to try a set. can always weld in some dimpled sheet to the bottom of the arm if they are weak.
says 1 year warranty on there? but that doesn't exactly mean you can get ahold of the company to replace them .
Old Jan 11, 2007 | 02:08 PM
djphonics's Avatar
The balljoints may also be complete ****. I don't know. Give em a try and post up results. I think I was one of the first people on here to get those Revo arms on a car and post up about it, and they are working fine so far.
...although I can't help but be sketched out by how cheap they are.
Old Jan 11, 2007 | 07:05 PM
ESP-net
Guest
Posts: n/a
Default Re: RHINO??? adj. upper control arms 88-91 civics (djphonics)
For $70 shipped I'll be the guinea pig just bought them for my h22 crx I will post results, yes they do look like revo's design... need to bring back my camber to -.25 on each side...UCA is more of a follower...strength of it should be fine...
From reading the feedback looks good...using words like skunk2 comparable...
Modified by ESP-net at 8:39 PM 1/11/2007
Old Jan 12, 2007 | 05:39 AM
Default Re: RHINO??? adj. upper control arms 88-91 civics (ESP-net)
nice. let us know how they are, especially the ball joints
Old Jan 12, 2007 | 10:34 AM
ESP-net
Guest
Posts: n/a
So far so good, they were sent out first thing this morning after purchasing them late last night and they went as far as giving my a phone number and tracking number... so far...
Old Jan 12, 2007 | 10:40 AM
Pee Wee's Avatar
ive been using em for a few months. different car but good results none the less. now im running -1.6 camber fully dumped. well worth the money. i got mine for even less
Modified by Pee Wee at 9:15 PM 1/24/2007
Old Jan 14, 2007 | 01:35 PM
K20EF8Dx's Avatar
Default Re: RHINO??? adj. upper control arms 88-91 civics (Pee Wee)
any problems pee wee??? does it look llike it would hit the fenderwell??? let us know...
Old Jan 14, 2007 | 01:42 PM
EJ6_ROY's Avatar
Default Re: RHINO??? adj. upper control arms 88-91 civics (K20EF8Dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EF8Dx &raquo;</TD></TR><TR><TD CLASS="quote">any problems pee wee??? does it look llike it would hit the fenderwell??? let us know... </TD></TR></TABLE>
x2 for Steve!!!!!
Old Jan 14, 2007 | 04:18 PM
swifty4u's Avatar
Default Re: RHINO??? adj. upper control arms 88-91 civics (rniederlando)
i was interested in them for an eg..guess it would be the same quality wise
Old Jan 14, 2007 | 04:37 PM
ESP-net
Guest
Posts: n/a
Default Re: RHINO??? adj. upper control arms 88-91 civics (swifty4u)
There shouldn't be any problems I have looked at them through pictures from people on H-T they look to be identical...revo and rrrrrrrrrhino....
Old Jan 20, 2007 | 07:03 PM
Project91Hatch's Avatar
are the balljoints replaceable on these? Can't really tell from the pictures.
Old Jan 20, 2007 | 07:16 PM
dkrex001's Avatar
Default Re: RHINO??? adj. upper control arms 88-91 civics (Project91Hatch)
good or bad
Old Jan 21, 2007 | 09:24 AM
Default Re: RHINO??? adj. upper control arms 88-91 civics (dkrex001)
I need to know if the balljoints are replaceable on these before I go ahead and get a set...
Old Jan 21, 2007 | 11:42 AM
IndySporty's Avatar
Peewee: with them adjusted fully outward does the balljoint or UCA hit the pinch weld inside the wheel well? That is the problem I always ran into with the "adjustable inner joint" type front camber kits; you had to grind off a bit of the end of the UCA and beat the pinch weld up and out in the wheel well or you'd end up riding on your UCA instead of your coilovers! Let us know what kind of clearance you have up there when slammed!
Old Jan 21, 2007 | 02:34 PM
ESP-net
Guest
Posts: n/a
Default Re: RHINO??? adj. upper control arms 88-91 civics (IndySporty)
I'll get some close up pix of them tom. probably going to install them sometime this week...
Old Jan 21, 2007 | 02:38 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP-net &raquo;</TD></TR><TR><TD CLASS="quote">I'll get some close up pix of them tom. probably going to install them sometime this week...</TD></TR></TABLE>
good stuff
Old Jan 21, 2007 | 05:02 PM
Crx Jimmy's Avatar
Default Re: RHINO??? adj. upper control arms 88-91 civics (Boosted Chemist)
I just got a set as well I couldn't resist the price. They look just like the revo ones everything looks good on them, only thing im going to change is the allen bolts that came with them, they came with grade 8.8 bolts( equal to grade 5 in us) so i'm going to swap them for some grade 10.9 regular head bolts
Old Jan 21, 2007 | 05:30 PM
Default Re: RHINO??? adj. upper control arms 88-91 civics (Crx Jimmy)
are the balljoints replaceable on them?
Old Jan 21, 2007 | 07:31 PM
rewerbcrx's Avatar
very interesting ... waiting for some response on fender wall clerance from ESP-net
and whether the are just as tuff
Old Jan 21, 2007 | 08:04 PM
ESP-net
Guest
Posts: n/a
Default Re: RHINO??? adj. upper control arms 88-91 civics (rewerbcrx)
I took a glance at it tonight and the ball joint doesn't look to be replaceable looks to be a 1 piece unit with the block...
For the Honda's I have owned I have never had to replace a UCA ball joint...so I think it will last me a while....
Old Jan 21, 2007 | 09:56 PM
I might go ahead and buy a set.
The outside of my tires are wearing FAST which means too much positive camber right? I hope not since these only allow you to do 0 + 3 I'm going to get an alignment and hope that its just my toe making the tires wear down fast.
Old Jan 22, 2007 | 04:51 AM
rewerbcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP-net &raquo;</TD></TR><TR><TD CLASS="quote">I took a glance at it tonight and the ball joint doesn't look to be replaceable looks to be a 1 piece unit with the block...
For the Honda's I have owned I have never had to replace a UCA ball joint...so I think it will last me a while.... </TD></TR></TABLE>
are they on the car yet? curious on how close they come to the fender wall...
Old Jan 22, 2007 | 05:55 AM
**** at that price just buy another camber kit
