Tranny Flush - how to refill?
Old Jan 11, 2007 | 11:30 AM
dynamo's Avatar
Default Tranny Flush - how to refill?
Kind of a dumb question - I am planning to do a tranny flush this weekend on a 94 accord Ex. I've seen a number of threads outlining the flushing procedure, but I can't find anything that explains how to refill the fluid back into the tranny (I am assuming it needs to be refilled until it's showing up at the correct level on the dipstick). Do any of you guys have a picture/diagram of where I should refill the fluid? TIA
Old Jan 11, 2007 | 11:31 AM
Ross 2.0's Avatar
In a Junkyard near you.
just refill it from the dipstick hole
Old Jan 11, 2007 | 11:37 AM
dynamo's Avatar
Default Re: (Ross 4107)
I thought there is an actual refill hole that needs to be used, but I can't find it?
Old Jan 11, 2007 | 11:41 AM
Tech-Nics's Avatar
the hole where the dipstick goes is the actual hole to refill a tranny. im assuming this is a AUTOMATIC EX. and you should really be using the Honda ATF fluid aswell...any other fluid is just not the same.
Old Jan 11, 2007 | 11:45 AM
Ross 2.0's Avatar
Default Re: (Tech-Nics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tech-Nics &raquo;</TD></TR><TR><TD CLASS="quote"> you should really be using the Honda ATF fluid aswell...any other fluid is just not the same. </TD></TR></TABLE>
Yep ATF-Z1 is the stuff to use
Old Jan 11, 2007 | 11:47 AM
dynamo's Avatar
Thanks for confirming - I'll do that. And I am definitely using the Honda ATF - OEM fluids for me all around.
Old Jan 11, 2007 | 04:37 PM
hondadude's Avatar
Default Re: Tranny Flush - how to refill? (dynamo)
Just to be sure you get it done correctly; you do know to check the trans fluid level with Engine Off. it should take 3 quarts if you are doing a drain and refill; Well the spec is 2.8 quarts, but the extra .2 won't hurt anything.
Old Jan 11, 2007 | 07:32 PM
sony224422's Avatar
Default Re: Tranny Flush - how to refill? (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Just to be sure you get it done correctly; you do know to check the trans fluid level with Engine Off. it should take 3 quarts if you are doing a drain and refill; Well the spec is 2.8 quarts, but the extra .2 won't hurt anything. </TD></TR></TABLE>
car has to be warm first though. and then you check it with it off. I think i put 3 in when i did it.
Old Jan 11, 2007 | 07:44 PM
dynamo's Avatar
Default Re: Tranny Flush - how to refill? (sony224422)
I checked the manual and it says that the transmission capacity (after a drain and refill) is 3.4qt, so that's what I added. Are you guys saying to put in 3 because you are thinking of a manual transmission? This is an automatic.
Old Jan 11, 2007 | 07:46 PM
sony224422's Avatar
well just check it the way you were told to and make sure its not too high. If its too high it will bubble out and then you won't have enough. Just as long as its in between the lines i wouldn't worry about it
Old Jan 12, 2007 | 05:38 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamo &raquo;</TD></TR><TR><TD CLASS="quote">I checked the manual and it says that the transmission capacity (after a drain and refill) is 3.4qt, so that's what I added. Are you guys saying to put in 3 because you are thinking of a manual transmission? This is an automatic.</TD></TR></TABLE>
That manual you have is a lying dog. Auto trans will take a little less than 3 quarts, and as far as checking it with the engine off and a 'HOT' engine,[never heard that one?] look out for the radiator hose.
bdmlilburn
Mar 28, 2009 02:03 PM
bmoua
Jun 26, 2006 10:02 PM
AlekSir
Mar 22, 2005 07:20 AM
davidnguyen
Oct 29, 2003 06:24 PM
TypeRuz
Oct 28, 2003 04:58 PM
