weird noise @ ~ 1050 RPM & 2000 RPM
Old Jan 11, 2007 | 09:02 AM
thatwhiteguy's Avatar
Default weird noise @ ~ 1050 RPM & 2000 RPM
I have a 98 GSR with what I believe is a 94 block and a 96 head, 95 ECU (yeah I know, fckin frankenstein car... got ripped off but that's another story) So anyway, when I'm in neutral and I rev it to just over 1k rpm, I hear a weird sound that sounds kinda like scraping metal... it goes away when I let off a little or gas a little, but when I take it up to 2k it does the same thing except slightly faster. It does it at other RPMs too but those are the only two I took note of. when I had my friend try to listen to where it was coming from, he listened to all over my engine bay but it was loudest near the wheels, both of them. I can't figure out wth it is... could it be my rotors just vibrating or something?
The sound is like metal scraping, and isn't constant.. it's like scrape *wait* scrape *wait* etc... for the life of me I can't figure out what it is. maybe you guys have some better ideas?
Also, slightly off topic question but how can I tell if my ECU is chipped? I'm running really rich and have alot of black build up on mybumper after just like 2 weeks of more or less normal driving. Also, my gas mileage is starting to suck more and more... when I first got the car it seemed a little better, I dunno what could be causing it. now I get like 200-240 to a tank.. it's probably because i'm running rich, right? and if I am running rich, is it because of a chipped ECU, or bad tuning, or what? Should I get it retuned? It's stock except I have the intake box off and it's lowered. If I do need to get it retuned, how much does that usually run and does anyone know of any good tuners in the CA Bay area?
Old Jan 11, 2007 | 09:57 AM
95 integra's Avatar
Default Re: weird noise @ ~ 1050 RPM & 2000 RPM (thatwhiteguy)
Heat shield or the "A" pipe (lower half of the header) is rattling. Very very common. Pull the ecu and look inside for a chip, thats the best way to tell. If its stock except for the intake box, then a stock ECU is best. Generally in city driving around 240 is avg (on 9.5-10 gallons of gas). I've gotten down around 180 on a tank with the right driving and temperatures.
rickyrocket
Engine Machining & Assembly
Oct 28, 2015 02:20 PM
kdubb03
May 28, 2008 05:16 AM
gohonda
Oct 15, 2007 03:48 PM
Haruspex
Feb 27, 2007 02:59 PM
Integgin
Feb 19, 2005 04:19 AM
