pr3 ecu vs. ls/vtec
All the archived searcnes that turned up show people run in with great success.
I am new to obd0, i usually do obdI builds. Do i have to make any changes to the harness? I assume i have to add the vtec/knock wires at the ecu....Anyone have a link to a pinout.
I will post some pics later, this is my neighbors (49 yrs old) CRX Si....he wanted something good on gas, with some "pep", so we built this thing.
the ls block has no place for the knock sensor so you'll have to modify the block or "ground out" that wire so it doesnt throw a code...a knock sensor code will make the car run like absolute ****...but still add the vtec wire for 2nd o2 sensor,vtec pressure/ground and vtec solenoid..
crx_si-r the obd0 pw0 and pr3 are basically the same thing so theres no advantage running one or the other..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman »</TD></TR><TR><TD CLASS="quote">so that diagram will work w\ a pwo and obdo ?</TD></TR></TABLE>
yes
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r »</TD></TR><TR><TD CLASS="quote">im gettin ready to run the ls vtec in a bit but i was gonna run a Pw0 will that one work out better than a PR3?</TD></TR></TABLE>
false...
they are pretty much the same maps, just vtec kicks in lower with the pw0...
but yeah get its chipped, i ran the feels PW0 on my b20-v and i was still super lean even the mugen was leaning out in the midrange
false...
crx.com
Feb 8, 2006 07:34 AM
