When turning car jerky and makes a grinding noise.
Old Jan 11, 2007 | 05:12 AM
ANGELIQUE's Avatar
Default When turning car jerky and makes a grinding noise.
I had an engine swap done about 6 months ago, right now i have a JDM B18c with B16 LSD tranny.
Everytime i make a turn it seems like the axles are jumping in and out of its socket. So it makes my car jerky and also makes a grindy noise. The steering wheel studders back and forth while the car is turning.
I've replaced the axles with b18c swap axles, i've replaced all 4 ball joints. What could the problem be?
Bad engine mounts? the b16 trannys mid-axle not right for the b18c? or do i just need an alignment. i haven't had one since my first swap. but on the hiway at 120-140 km/hr the car is still smooth.
help please.
Old Jan 11, 2007 | 06:02 AM
be.twenty's Avatar
check your wheel bearings... it may be pretty bad if your car is jerking around..
wheel bearings usually give the grinding noise... you may notice it more when turning but it will make the noise even when going straight.
Old Jan 11, 2007 | 06:34 AM
ANGELIQUE's Avatar
no its not a wheel bearing grinding noise...it sounds like its coming from the axles
Old Jan 11, 2007 | 07:18 AM
be.twenty's Avatar
Default Re: (ANGELIQUE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ANGELIQUE &raquo;</TD></TR><TR><TD CLASS="quote">no its not a wheel bearing grinding noise...it sounds like its coming from the axles</TD></TR></TABLE>
are you leaking from any CV joints or boots?
Old Jan 11, 2007 | 11:19 AM
ANGELIQUE's Avatar
Default Re: (be.twenty)
nope..i replaced the axles with new ones...and it still does this
Old Jan 11, 2007 | 08:53 PM
ltrostabotch's Avatar
lossen ur axle nut and check the bearing for play
Old Jan 12, 2007 | 10:52 AM
ANGELIQUE's Avatar
wheel bearing is fine
Old Jan 12, 2007 | 01:20 PM
Sam92Teg's Avatar
Did you match the right axle with your intermediate shaft? Also, if you bought remans, some are crap right out of the box.
Old Jan 12, 2007 | 01:45 PM
ANGELIQUE's Avatar
Default Re: (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Did you match the right axle with your intermediate shaft? Also, if you bought remans, some are crap right out of the box.</TD></TR></TABLE>
does a b16 tranny's intermdiate shaft match up with b18c axles?
Old Jan 12, 2007 | 02:59 PM
jdm_bones's Avatar
does a b16 tranny's intermdiate shaft match up with b18c axles?</TD></TR></TABLE>
yes they do...it sounds like your axles aren't all the way in! my GF LS had this problem, inproper install, tranny ended up grinding the teeth on the axle, take them out and check the teeth on the axles, then make sure that when you put them back in the C clip on the axles engages. That could've been your problem, when you installed them...
Old Jan 12, 2007 | 03:59 PM
CompanyFlow's Avatar
Default Re: When turning car jerky and makes a grinding noise. (ANGELIQUE)
Do you have powersteering?
Old Jan 12, 2007 | 07:16 PM
ANGELIQUE's Avatar
Default Re: When turning car jerky and makes a grinding noise. (CompanyFlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">Do you have powersteering?</TD></TR></TABLE>
Yes i have power steering
Old Jan 12, 2007 | 08:02 PM
Could be powersteering related. Had an LS400 witha bad powersteering pump and the thing would GRIND whenever the steeringwheel was moved. The wheel bearing would make more of a whining sound than a grinding sound. Start with the smallest possible problem and work your way up from there.
Old Jan 12, 2007 | 10:12 PM
gsr dood's Avatar
take ur power steering belt off and see if its the belt or the pump. my ac belt made a real disturbing grinding noise for about 2 months i thought it was my flywheel/clutch....turned out to be the ac belt...it was soo wierd but if ur getting the gring when turning i would def take the ps belt off and see if it still makes the noise around turns. it takes like 2 mins to take that belt off
Old Apr 5, 2007 | 07:38 AM
ANGELIQUE's Avatar
Default Re: When turning car jerky and makes a grinding noise. (gsr dood)
still have the problem...the grinding sound seems like its coming from the tranny now..i think its a bad lsd? also there's some slipping which makes the car jerky. this only happens when i'm in gear and giving gas....when i'm outta gear turning there's nothing wrong.
so is this a bad tranny or lsd?
Old Apr 5, 2007 | 08:09 AM
Tyounin608's Avatar
Try checking the transmission fluid for shavings should tell you if it's an internal tranny problem, or would atleast be a start
phly
Oct 8, 2010 10:45 PM
ANGELIQUE
Jan 12, 2007 09:59 AM
ANGELIQUE
Jan 11, 2007 07:18 PM
spender1326
May 31, 2005 05:27 PM
631 Teggy
Dec 29, 2003 07:55 PM
