california zc smoggin
Old Jan 11, 2007 | 02:51 AM
samsong's Avatar
Default california zc smoggin
just some questions to make things clear...
zc's came from japan and were never distributed to the usdm right?
would having a zc in an EF would conflict with CA smog? ie diff motor n what not..
Old Jan 11, 2007 | 03:15 AM
661rex89si's Avatar
the single cam zc non vtec can pass smog because its identical to the d16a6 minus the different cam. the dohc zc some people have been able to pass them in cali but can only be swaped in 88-89 crx or civic chassis. but you have to try and pass it as a d16a1 swap so its a but tricky than the sohc zc to pass.
Modified by 661rex89si at 5:44 AM 1/11/2007
Old Jan 11, 2007 | 03:23 AM
samsong's Avatar
Default Re: (661rex89si)
ohhhh ic....
cause theres this 90 ef hatch si with a 80k zc motor in it and claims to have 130hp stock. im guessing its sohc, but not sure though
Old Jan 11, 2007 | 04:21 AM
661rex89si's Avatar
130hp would be in the realm of the dohc zc the most i hear the sohc zc's put out stock is 118hp
jdm.swift
29
Oct 29, 2010 01:14 PM
theredegg
May 28, 2009 08:01 PM
hatchinprogress
17
May 29, 2005 05:03 PM
zdr262
Feb 15, 2004 12:19 PM
