I have 2 turbos cant decide wich to use for my project!!
Turbonetics tubo t3/t4, hot .63 stage 3, cold 57 trim A/R not sure
Precision turbo t3/t4, only spec on turbo i have is cold side A/R .60 that came from a rev-hard stage 2 kit
Wich of these has more power potential?
Any one know the power potential of either?
Thanks.
Thanks.
57 trims are usually good upwards of between 300-400whp the precision is good for about the same maybe a little more. either way they are both very nice turbo's
Im using a hybrid, i grabbed the exhaust housing from the turbonetics and compressor housing from precision, worked out pretty good and pretty decent spool up. Peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaddict14 »</TD></TR><TR><TD CLASS="quote">57 trims are usually good upwards of between 300-400whp the precision is good for about the same maybe a little more. either way they are both very nice turbo's</TD></TR></TABLE>
is this 300-400 whp or crank hp
1.8L dohc vtec + 57 trim + ~22psi on pump = ~400whp
I would go with the turbo with the best seals (as in try them both out), but I would side with precision if both are the same that way. They seem to have less issues than turbonetics.
Thanks for the info, im going to go with the Turbonetics turbo because I know the seals are already bad on the Precision my origanal plans was to rebuild the Precision but if I can get the same power from the other I wont bother right now and keep it as a back up.
